Question about Princeton Digital VL1918 Monitor
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
I'm considering buying an HP computer with a NVIDIA GeForce 6150 SE and need to know if my old monitor Princeton VL1918 will support it
  • 20 Answers
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Posted on Mar 27, 2008
SOURCE:
Code purple
this is problem with VGA connectors pins if that is soled properly then the cable of monitor is damaged and need replacement.
if you check cable is fine then replace the Colore IC of monitor
May 11, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
My computer freezes and makes a long beeping sound then no signal to monitor, beeping continues till manually shut down.
There are several reasons why a computer will lock up. You can view the HP help file HERE for your computer. You can also view the beep codes for your computer (yes, those noises mean something :D ) HERE. The instructions are step by step for your machine and should be fairly easy to follow.
Good Luck
Aug 26, 2010 | HP COMPAQ Presario SR5510F Athlon 64 X2...
Need to download drivers for a princeton vl1918 HELP!
open the internet and open the link www.softwaredriverdownload.com/princeton_graphics_vl2018w_driver.html - United States and you can instantly download the drivers
Mar 28, 2010 | Princeton Digital VL1918 Monitor
Foxconn LAN driver
Need to let us know what operating system you are running for driver information...and if it is Vista we need to know if it is 32 bit or 64 bit. If you are not sure, right click on My Computer and it will tell you on the window.
Sep 06, 2009 | HP PAVILION a6500z- AMD Sempron LE1300 ,...
Princeton vl1918 flashes on than off
See previous solution for Princton Monitor cycling on and off.
Solution: Change out 3 capacitors.
Jul 15, 2009 | Princeton Digital VL1918 Monitor
How is the cover removed from the Princeton VL1918
Theres sort of clips that clips to the side of the monitor's frame, use a flat screwdrive to care fully push through the sides of the LCD to unlock the clips.
Nov 15, 2008 | Princeton Digital VL1918 Monitor
Driver
Even though it is a Nvidia GeForce card, you want to use the HP drivers. Laptop video cards are set up a little different then desktop video cards.
Here's the link to that drive page.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-42641-1&lc=en&cc=us&lang=en&os=228&product=3224052&dlc=en
Aug 09, 2008 | HP Pavilion dv6000z Notebook
Princeton monitor
check www.badcaps.net - they have a tutorial on their site for replacing caps, it's for motherboards- but the technique is the same.
I ordered caps for the Princeton Monitor VL1918 from Mouser.com and got their item # 647-UHE1E471MPD6
The 470uf 25v caps size- 10x16 mm
Mar 11, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
265 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Sr. Pelo
Sr. Pelo
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
