Question about Garden
Riding mower dies after blades are switched on. The Seat switch had been disabled before and was working fine. Just all of a sudden while cutting the mower stopped. Nothing in the the blades or hindering the belt. New plugs, new battery, new relay what else could be the problem?
  • 134 Answers
Please provide your brand and model number.
First, the seat safety switch should be enabled (for the safety of you and others).
There is another safety interlock integral with the blade engagement system. With your brand and model we can probably find that switch...if the problem.
Does the mower run when the blade system is disengaged?
If no, then a possibility is the ignition system.
Posted on May 07, 2010
Model 40808X14A. When blades are engaged, why does mower die?
Most likely something is jamming a blade.
Another possibility is the reversing safety switch is stuck which cuts the engine spark.
Apr 15, 2016 | Murray Garden
My ride on lawn mower is cutting out every time i try to engage the cutting blades
Sometimes it is due to the ETHANOL fuel you are using. ETHANOL is attracting moisture and after a while it builds up water in the tank.
Jul 06, 2015 | Garden
Mower runs fine turn on blades it will die
MikeMake sure that the blades will turn by hand (key out of switch- unplug the sparkplug wires!!!!) there could be a dirt mound or rock jammed in there. OR-
if you\'re in the seat and the engine dies just as soon as the blades are engaged, the engine may need a tune-up. It sounds like it starves for fuel or air under load.
May 04, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower runs fine.when u turn on blades it will die
There is a switch under the seat made to turn off the engine when the blades are "on". You have to be sitting on the seat to engage the blades. If you are, check to see if that switch is plugged into the harness. If it already is, you probably need a new switch, or less likely, but possible, the harness is damaged somewhere up the line.
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Engine cuts out immediately when blades are engaged - new mower
Check the seat switch. If it is loose/out of adjustment, the mower will die when the blade is engaged. The logic of the mower requires the operator to be present (on the seat) for the blades to engage, or for the mower to move. All of the safety switches are dependent on the seat switch. Dirty connections at the switch, or the switch being out of position is the likely culprit.
Best regards, --W/D--
Jun 04, 2011 | Husqvarna Garden
My Craftsman 42" 18.5hp lawn tractor will start fine but when I disengage the brake or engage the blades it cuts off. It was recently left out in the rain while I was working, did something short out? It...
there is a safety switch under the seat. to stay running after the brake is released or deck engaged you have to be sitting on the seat or it will die. if this switch is bad it will die as soon as you release the brake.
Aug 25, 2010 | Craftsman Garden
Mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Jun 02, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
