Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
What faults do the flashing light codes indicate on a dynamic dl 5.2i wheelchair controller?
5 Suggested Answers
  • 175 Answers
SOURCE: working on a pride wheelchair that i just put (2)
First, make sure that the motors are both engaged and not in freewheel, and that the charger is unplugged. If it is a constant flash without pause, this is usually an indication that the joystick is "out of neutral", a problem caused by hitting running the joystick handle under a table, for instance, of moisture in the joystick itself. If it is a series of flashes, like 4, pause repeat, then you have a fault somewhere else in the chair. Here's a link to the flash codes for your controller. http://www.dynamiccontrols.com/index.cfm/3,73,237/dna-flash-codes-0307.pdf The flashes, types and manner of flash need to be better described in your posting. Good luck.
Posted on Jan 08, 2010
  • 7 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair, it is the secondd row of ligths on the controller, the ones that indicate speed. They are flasing steadily
Check that you don't have the charger cord still connected or the motor disengaged.
Posted on Jun 01, 2010
HoverTech
  • 232 Answers
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
  • 50 Answers
SOURCE: I have an Invacare P9000 XDT wheelchair. I keep
Hi DREADFULPCBU
There isn't much to the P9000 joystick and controller. First and formost have your batteries load tested to ensure you have 24 volts dc. That in itself may solve the problem. I would then check each and every wire connection to make sure there is good continuity on all metal connectors. Check the voltage to ensure ther is only 24-27 volts dc. You could also have an over voltage possibly caused by a short somewhere. Has your chair ever gotton wet? If so one of the motors could be shorted out. Test this by taking out the motor brushes (one at a time) .See if it has water or oil on it. If so you may need to replace that motor. If all that is ok then here is where you can send your joystick and controller for repairs. ( I'm not confident that the ones you got from the junk yard are good.
PG Drives Technology Inc 2532 East Cerritos Avenue
Anaheim,
California 92806-5627
USA
Tel: +1 714 712 7911
Fax: +1 714 978 9512
www.pgdt.com
Good Luck
mimobility
Posted on May 04, 2011
Yellow wrench light ctm hs 1000
Usually a generic 'trouble' indicator. Can you read out the error codes or fault log?
Aug 20, 2014 | Health & Beauty
Lock key keeps blinkinglights blink 9 times
Depending on the controller type being used you either have a controller solenoid brake fault (sticker on bottom of joystick will say "PG Drives" and have 9-bars flashing) or a communication error between the controller and joystick (Dynamic Controller flashing wrench).
Repair for PG Drive is to replace joystick/controller.
Repair for Dynamic is to clean, remove and reseat or replace joystick cable.
Nov 12, 2013 | Pride Jazzy Select 6 Indoor Power...
Flash code is 5 flashes pause then 5 flashes what does 5 flashes mran
What controller??? For a Dynamic Controller it is an error code 5: left park brake fault. Check the brake connections.
Jan 15, 2013 | Pride Mobility Products Jazzy Select 14 XL...
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
Jul 15, 2010 | Health & Beauty
Merits wheelchair has a dynamics d l 4.2j controller
Hi. You say that the lights blink? Do all the lights blink, or just some. If its just a few then it is probably a fault code. Count how many lights are flashing and let us know and I will be able to look it up. Do you have either of the motors in free-wheel. The brake units have small micro-switchs on them, and the controller will not operate in either switch is on. Also check all battery and motor connectors. Good luck. Neil.
May 26, 2010 | Electric Health & Beauty
Working on a pride wheelchair that i just put (2) 12v33 amp batteries in. im getting 24 volts to the controls but the control only flashes and motor wont even try to engage. its a dl 5.2i dynamic...
Jan 07, 2010 | Pride Health & Beauty
Go to turn the power on the controller of a Jazzy 1143. The lights on the controller flash and no power goees to the chair. Have checked all connections and still nothing works.
Flashing lights indicates a fault. Here' the users manual which contains the fault codes for the flashing lights. Repost with more info re: the fault codes. Good Luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jazzy_1143_om.pdf
Also, make sure the charger is not plugged into the chair.
Jun 06, 2009 | Pride Jazzy 1113 Power Chair
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
630 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
