Question about Kenmore HE2 Plus Front Load Washer
We keep getting an F21 message on the machine and the machine quits working how can I reset.
    President:
  • 1,554 Answers
Press Pause/Cancel button twice to clear the display then check the drain hose for kinks and clogs. Error code F21 indicates a long drain error. The drain hose is most likely clogged or the drain pump is not working properly. Check the pump filter and the impeller and make sure there's no obstruction that might be causing the water not to be pumped out efficiently.
Posted on May 07, 2010
  • Jahn27
    Jahn27 May 07, 2010
    The drain pump can be accessed by removing the lower front access panel. Remove the screws securing it to the cabinet then slide it down and off. Place a towel under the pump then unscrew the pump filter from the pump housing and pull it out. Clean the filter including the pump housing and check the pump impeller, water will not be pumped if it is broken.
    With the lower front access panel still removed, set the washer to drain mode if everything is clear then verify the operation of the washer. Check the pump wiring connections if the pump is not running. Replace the pump if the connections are good and snug fit.
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
He2 plus front load washer keeps showing f21 error code i cleared the drain pump filter and it still displays the error code f21 how do i check to see if the pump is not working
Hi
CCU/Touchpad/LED assembly error (f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. This will reset the CCU, and may reactivate the communication if the damage isn't severing. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU).
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine will not drain and keeps giving me a F21 code...what do I do? I have unplugged to reset it and and have tried to run the drain cycle numerous times...no luck. Help!
f21 is long drain error heres a video of how someone else fixed the problem http://www.youtube.com/watch?v=qQTvBSnEWsI note this is not me lol if you have any further questions message me back and please remember to rank this opinion it allows me to help others in the future in similar situations thanks Rick
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F21 on the Kenmore HE2 Plus Frontload Washer
there is a removable access panel on the front of the machine under the door. Remove one screw from each side. There you will find the pump that has a strainer basket on it. Remove that and clean the blockage out of there. You will also find attached to the panel, another manual that explains the codes better
Dec 27, 2009 | Kenmore HE2 Plus Front Load Washer
Was ''F35'' now its ''F21''
F21 is drain problem.
Try tripping circuit breaker to reset the appliance.
The next step will be undoing the drain pump hose to check for a blockage.
the pump is accessed removing a panel, usually at the front side of the machine.
Steps are explained on user manual.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Kenmore Washing Machines
Washer don't work (F21) message
The "F21" error is a "Long Drain" error code. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If you still require assistance, please let me know.
Jan 07, 2009 | Kenmore 46462 Front Load Washer
F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
May 06, 2007 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
292 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
