Question about Acer Aspire 5050-3371 Notebook
When I start my laptop, it say Oxc00000e9 problem. Any method to solve? thanks.
    Novelist:
  • 76 Answers
Hi ,
This error can be caused by unplugging a removable storage device such as an external USB drive while the device is in use, or by faulty hardware such as a hard drive or CD-ROM drive that is failing. Make sure any removable storage is properly connected and then restart your computer.U can also do this disconenct all the external devices and then check if you get the error message or not.If you dont get the error it means that there is an external device that is causing the error to come and to find out the faulty device check by conencting one device at a time and restart .
You ca also try this step,turn the computer off and then tapp the F8 key repeatedly as soon as you release the power button after pressing it .Keep on tapping the key until you get a black screen that says advance boot menu option.Then select safe mode and hit the enter key ,wait till it takes you to the log on screen.Once you are there click on admininstrator and hit enter key ,check if you get the error or not .If u dont get the error go to start?run?type msconfig?hit enter?you get the system confuguration page?click on the the start up tab ?click disable all ?apply?click on the services tab? click disable all ?apply ?click on ok or close to exit from the page and then clik on restart when it prompts you to .Then the computer will take you to the normal mode check if you get the error or not if you dont then there is a program that is gone currupt and is causing the error to come up .To find what program has gone corrupt again go to the configuration page and then enable the startup programs restart the computer if u dont get the error go to the servoces tab uncheck one or more program restart and then check so this way you will have to isolate the program that is causing the error to come up and once you find the program just uncheck that particular program this will take care of the issue .
hope this post helps you ....all the best
Posted on May 09, 2010
Error Oxc00000e9 can this be fixed please
Sadly reformatting your hard drive and re-installing youre OS is the only solution. Had the same problem before after the Windows update i think.
Jun 18, 2011 | Dell Inspiron 1525 Laptop
When I try to turn on my laptop, it starts loading and freezes while loading files. then the "Windows Boot Manager" screen appears and it reads, "Windows has encountered a problem...
Please make sure all devices are connected to your computer properly. Access it in safe mode and I am sure it would run, in in the safe mode just clean Windows registry database using some reliable software such as Reginout Cleaner. After cleanup process, start your computer normally.
Hope it would help you.
Jun 01, 2011 | Toshiba Satellite P205D-S7802 Notebook
L305-s5947 toshiba stallite laptop oxc00000e9 error an unexpected i/o error has occured
These error messages may be caused by the WORM_KLEZ.E virus, or one of its variations. The executable file name "qbw32[xxx].exe" may vary, where "[xxx].exe" is a randomly generated and false executable name.
Run norton antivirus or microsoft antivirus and check your computer for viruses....
that should solve your problem.
Hope that helps.
Feb 27, 2011 | Toshiba Computers & Internet
Error Oxc00000e9 when i turn on aspire 5741, no external devices plugged in.
try this below
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Feb 14, 2011 | Acer Aspire 5050-3371 Notebook
Upon startup my toshiba laptop displays status Oxc00000e9 what can i do
buy a mac. vista and microsoft ****!!! YOU ARE WASTING HOURS OF YOUR LIFE DEALING WITH THIS BS. I HAVE THE SAME PROBLEM. status Oxc00000e9
I HATE MICROSOFT
Oct 11, 2010 | Toshiba Computers & Internet
I just shut down my vaio and when I came back to open windows my fingerprint scanner wasnt working and the cpu was not recognizing any usb drives that i was plugging in to it.
Method 1:
Press F8 during system Startup.
Select "Last known good configuration that works"
Check it has solve the problem or not.If the problem still persists follow the next method.
Method 2:
Click "Start Button"
Select "All programs"
Select "Accessories"
Select " Sytem Tools"
Click "System restore"
and restore the system to a point or time when you knwo it was working fine.
This will solve your Problem.
Jan 02, 2010 | Computers & Internet
I get an eror message status Oxc00000e9 what does
There are 3 step to repair oxc00000e9 error
If you got oxc00000e9 error then there is a 94% chance that your computer has registry problems. To repair oxc00000e9 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair oxc00000e9 error.
Here are the url of Perfect Optimizer:http://www.nomoreerror.com/tidpp-oxc0000… Source(s): http://www.nomoreerror.com/tidpp-oxc0000…
Nov 24, 2009 | Acer Aspire 5050-3371 Notebook
Laptop
as i see u forgot urs pass word right...
fallow dis steps as i m telling u...
<<<1st method...>>>
u can solve it frm windows safe mode when ur computer start immediatly press F8 for 3-4 times
a new windows open
in it select safe mode...
after startin windows u can make a new account by doin dis..
start>control panel>user account>creat a new account..
den restart urs computer u can acces urs computer..
<<<<<2nd method>>>>
or u can also try dis when urs password dailog box comes press ctrl+alt+del a new dailog box open in it dere is user name and password
type ADMINISTRATOR as user name
nd type ADMINISTRATOR as password....
u can aceess urs pc.....
thanks...
Jun 28, 2008 | HP Compaq Presario V6000T Notebook
Acer Aspire 5050-3371 Notebook Logo
348 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
