Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 52 in.... Problem:
Which one is the FMT?
  • Mitsubishi Master
  • 8,617 Answers
Its the board that the rectangular board with the inputs plugs into.its on the right hand side of the chassis.
Posted on Mar 27, 2008
How do I fix DVI cable between FMT and Engine disconnected
Are you sure its disconnected? It may have a FMT failure. The cable is inside the back of the TV. you need to remove the rear panel to see it. There should be a white ended cable that plugs in that looks like a monitor wire but short.
Sep 15, 2015 | Mitsubishi Televison & Video
Hi i have a mitsubishi WD-52525 and the timer light just keeps flashing and the tv wont power on....whats wrong with it?
Check for bad cap on DM & FMT modules 1000uf at 25volts caps to E2P module.
Credit: http://www.repairworld.com
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green diagonal lines
the FMT caps have most likely failed. You can get the V26 FMT repair kit from www.tvrepairworld.com which also contains instructions.
Aug 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Green lines thru picture like some open the shades
If the menu is clear without the lines then chances are its failed caps on the FMT board. You can get the V26 FMT repair kit from the following link which also includes instructions for the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Have a mitsubishi model wd-62327.lost power now it turns on but no audio or video through any connentions
paid $40 to have a tech look at mine and said its the fmt pcb: 930B931001 & signal pcb : 930B30001
Oct 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Wd 57732 won't turn on, power/timer light blinks
probably something related to the FMT board. will need shop service.
Aug 30, 2009 | Mitsubishi WD-57732 Projection Television
Mits WD-52525 random 1-pixel jitter
if you are a profetional replaced all capacitors on FMT and DM board.. or replaced the chassis........
DM and FMT board N/L/A .........
Jun 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv won't turn on?
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Dec 27, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
