Question about Meade DS-114EC (325 x 60mm) Telescope
Need replacement power supply for Mead Model
Need replacement AA battery power supply for Mead Model DS114EC Reflective Electronic
  • 3,186 Answers
Contact Meade directly for a replacement at this web site:
http://www.meade.com/support/index.html
Posted on May 07, 2010
Casio ecr change battery
Depends upon the model. Some are internal rechargeable, and some are AA batteries near the paper rolls. If you replace the batteries, always leave the power ON with screen lit up as you change them so you don't lose your program.
Sep 27, 2017 | Retail Supplies
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
What is the output voltage, amperage, watts and polarity for Schwinn 203 recumbent bike? I have a pile of transformers and don't know which one my mother-in-law used. Thanks for all replies.
If the recumbent digital computer gives you an option of power supply or batteries then you can deduce voltage of the power supply by counting the number of batteries needed times 1.5 (1.5 volts = voltage of AA or AAA battery).
You can deduce typical current by multiplying the number of batteries by: AA = .05 amps or AAA = .01 amps.
Your next issue will be to deduce the polarity. Look at the Schwinn to look for a symbol that will show you polarity. Typically the center of the plug is: + positive and the outer shell is - negative. There are instances where those two are reversed.
If this is all too confusing then Google the recumbent model number to find replacement power supplies ($35 to $45 US).
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Nov 28, 2014 | Schwinn Cycling
Battery power ac card optional
Proprietary? The GE A730 uses standard AA batteries. If you choose to use rechargeable batteries then you can charge them using any standard AA charger. Such chargers should be available at just about any department, electronics, or office-supply store.
Jan 13, 2014 | GE A730 Digital Camera
My samsung n150 mini, was working very well.suddenly, the screen turns into black and no sound of the processor. Screen and battery flashlight indicates that they dont work.what is happening?
Does the laptop start up with power adaptor plugged in?
If yes then battery may be dead, you can check for a replacement online, battery model may be AA-PB2VC6B but check the battery label to ensure you note the correct battery model.
If the laptop does not boot with the power adaptor inserted, remove the battery and try booting with just power supply inserted and see if laptop boots.
If still not booting then it is a hardware fault, either battery, power adaptor or internal part possibly motherboard, you will have to contact Samsung for repair.
Good Luck
Jan 10, 2013 | Computers & Internet
10" LX200 runaway motor, right ascension.Mead
The very first thing to try is new cables. Including the DEC cable. If this does not repair it then it has an internal circuit board issue.
Buy new cables first--
www.scopestuff.com sells them. Call them and order everything new.
Also a low power supply can also cause this-- and would be the second thing I would check. You are using a separate 12volt power pack -- correct?
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Jul 24, 2011 | Meade Optics
I have a meade 4501 telescope. It has an
See if a manual is listed on the Meade site Here:
http://www.meade.com/manuals/index.html
That shows the power supply voltage.
Jul 12, 2009 | Meade Optics
Batteries weak
Hi, Don't know the make and model of your safe but this advice works for sentry safes,if it doesn't help you get back to me with a make and model: If you need to know how to put batteries in, Turn the electronic lock clockwise ( to the right) from the 12 o'clock position to the 2 o'clock position which opens it so you can put in 4 fresh AA batteries replace the assembly by turning it to the left from the 2 o'clock back to the 12 o'clock. enter your combination and check for the green light. Good Luck!
Feb 08, 2009 | Safe International Digital Electronic Safe...
Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
Jan 31, 2009 | Casio TE-2000 PC Desktop
Meade DS-114EC (325 x 60mm) Telescope Logo
101 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
