Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My front wheels are suddenly out of alignment. I
My front wheels are suddenly out of alignment. I have no idea why, I am not aware of any collisions, I do not see any bent or damaged parts, frame or linkage. Is there any way to adjust back into alignment?
  • bighackr May 10, 2010
    Thanks sml55, parts are on order. I'll post back how I make out
    Problem Solver:
  • 16 Answers
There are plastic bushings on the front wheels that get worn over time. Pull the front wheels off and inspect them to see if they are still intact.
Posted on May 07, 2010
Testimonial: "Thanks for the feedback, the parts are on order, one side appeared more worn than the other. I'll let you know how I make out. Again, appreciate the help."
My 2011 MKX front wheels start shaking badly, then the brakes lock up. The anti-traction light is on and the collision avoidance system says it is not available.
if the shaking starts at around 30 mph have a wheel alignment done as it indicates a castor wobble problem
have the front end and suspension checked for worn steering joints , ball joints and wheel bearings
Oct 24, 2017 | Cars & Trucks
I have a 2003 ford explorer 2wd. It sways all over the road at highway speeds 55. Don't notice it at lower speeds. Any ideas?
There are numerous things that may cause this issue. Start with tire pressure at proper amount on all wheels. Next, have the front end steering/suspension checked for loose/worn parts. An alignment may be needed as well.
Jan 05, 2016 | Ford Cars & Trucks
03'nissan frontier4x4crewcab v6 which parts need to b replaced before alignment
have the front suspension and steering inspected by an accredited suspension shop to get some idea of what is needed
normally it is upper and lower ball joints or lower ball joints and struts and steering rod ball joints
they can also do a wheel alignment and if you haggle with them they may do the alignment for free if they get to replace the worn parts
don't forget that a proper wheel alignment means that the rear wheels are properly aligned to the chassis first before the front wheels are done
Aug 22, 2015 | Cars & Trucks
Front end alignment
Get the four wheel alignment if you heave never had it done. Be aware that on the rear the adjuster bolts may jammed with rust. On the front, the ball joints, rod ends and strut bolts need to be on good condition.
Jan 19, 2014 | Subaru Impreza Cars & Trucks
Steering wheel tilted
This is a common problem. The last time the aligned it the may have bumped the steering wheel and when they aligned it and tightened everything back up it was off center. The next time you get it aligned make them aware and they'll straighten it up for ya.
Dec 01, 2013 | 1994 Pontiac Firebird
Roaring noise with my 2006 Chevy Cobalt?
while the wheel bearings still feel tight they are the cause of your problem, after a collision most cars suffer from this problem depending on the speed of the accident the forces encountered during a sudden stop causes intense stress and fatigue on the bearings
Dec 06, 2012 | 2006 Chevrolet Cobalt
We have a 2004 60R withch has been great until a minor frontend, parking lot, collision a year ago.. the fron bumper was replace4d and the headlights have never worked well since. They point so rar down...
NEED TO LET A BODY SHOP CHECK OUT FRONT UNIBODY STRUCTURE FOR DAMAGE WHEN YOU HAD A FRONT END COLLISION. IF FRONT STRUCTURE BEND OR DAMAGED. THE FRONT BUMPER AND HEADLIGHTS FRONT WHEEL ALIGNMENT GOING TO BE OFF.SOUND LIKE FRONT END COLLISION IMPACT DAMAGED THE FRONT UNIBODY STRUCTURE.
Jul 10, 2011 | 2004 Volvo S60
Top of front wheels tilt outward. What needs to be adjusted?
You Have a camber problem. Check the front control arms. Sometimes there are adjustment for the control arms. Be aware that you will need to have the vehicle on a wheel alignment machine to get accurate results.
Dec 20, 2010 | 1999 Chevrolet Tahoe
My Lincoln 2002 LS suddenly pulles to the right like some one turned the steering wheel at highway speed. obviously its very dangerous,thank you,Eric
Somethjng is not right with the front suspension of you car. Might be a bent part, something is wear out, or loose. This is dangerous and your tire will create bias, so will cost you more. This car needs a front suspension inspection, and alignment check. We do this service at our dealership 4 wheel alignment $75. GM charge $75 for front wheel alignment, parts extra. Any suspension repair shop can give you a good answer.
Nov 01, 2010 | 2002 Lincoln LS
1996 jeep cherokee sport shakes badly over 40mph
Front end need to be checked. checked shocks and stabilizer links.
check damper shock.
Check the tie rods. They had come loose, causing the wheels have excessive play and vibrate. Be aware that they will not balance tires or give a front end alignment if the tie rods are the culprit. They must be replaced first, otherwise the alignment will only hold until the first time you turn the wheel...which could be 5 seconds after you get in the car. Good luck.
Oct 30, 2009 | 1996 Jeep Grand Cherokee
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,869 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
