Question about GE JVM1650 1000 Watts Microwave Oven
GE Microwave model JVM1650CH01. Trying to replace door handle." I have removed panel on inside of door and removed 2 screws to handle. It appears that there are screws holding the outside cover of door handle to door. I cannot get to this other set of screws. How do I get to these screws?
    President:
  • 949 Answers
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
Posted on May 07, 2010
I posted a solution to this here.
This was for a GE JVM1650BB005, but I believe the solution is the same.
Posted on Apr 13, 2012
GE JVM1660AB002 Microwave door handle broke at the bottom. I removed part of the inner plastic door panel, but can't get the panel removed from the main door at the side where the hinges are attached....
Hello & Welcome to FixYa
Please review this video if you want to replace it yourself:
Please get back to me if you have any other questions.
Kevin
Jul 14, 2011 | GE JVM1660 Microwave Oven
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke off my GE Advantium 120 microwave door (model #SCA1000DCC03). I just ordered a replacement handle (PRT #WB15X10071) but I need instructions on how to replace it. The screws are hidden inside...
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Sep 16, 2009 | GE Advantium 120 Convection/Microwave Oven
How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reair microwave handle
You may have to rotate or lift the handle.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sep 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Oct 08, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
429 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
