Question about Dacor Epicure EOG52 Grill
Why does the side burner igniter stay on (clicking and sparking) while I have the main burner on? How can I reduce the flame on the side burner, currently the lowest setting is too high.
  • mike66520 May 09, 2010
    The ingniter is powered by 120 volts not batteries.
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why won't my gas grill stay lit?
GAS OVENS
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
Jul 04, 2014 | Zanussi Ovens
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
My ovens wont stay alight i have a twin range gas oven and it just wont stay lit but if i hold the knob in it stays lit
I offer free advice bcuz God is so good!
GAS OVENS
ELECTRIC OVENS:
: I offer free advice bcuz God is so good!
Jul 31, 2011 | Belling Ovens
Hi I have an H400 hayward. when heater is activated, it stays on for 5 seconds then shuts down eventually reading ignition failure code or IF on screen. the ignitor is new, the heat sensor is new, the gas...
When you say it stays on, Does the main burner actually light? If the burner never lights, then I'd look closely at the igniter, as it also acts as the flame sensor. Possibly you have a good enough ground to get a spark, but not good enough to sense the flame. If the main flame is starting, look and see if it is blowing off of the igniter. If this is the case, perhaps it isn't in the correct position, or there are still a few dirty passageways in the main burner. You can download a manual for your heater here: http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
Aug 10, 2010 | Hayward H400 High Wind Stack
How do i start the pilot light on a JGBP28wek6ww
That model is an electronic ignition, ther isn't a standing pilot on it(no liitle flame that stays lit). Light the burner by pushing in on the knob and turnlig to "LITE" position, you will hear a clicking noise the sound of the electric spark igniting the burner, turn the knob to adjust the flame size. Keep in mind that all igniters spark whenever any of the knobs are turned to the "LITE" position. Good luck !
Nov 30, 2009 | Televison & Video
Electronic ignitor does not recognize that flame is on thus does not stop clicking
A generic troubleshooting response would be...... if the burner won't stay on, either the igniter or the ignition module (or both) are bad. If the burner ignites and stays on but the spark module keeps trying to ignite, the module must be bad.
Sep 14, 2009 | DCS Microwave Ovens
Viking 6 burner range that keeps clicking after ignition
Spark ignition sparks until the flame starts. The flame ionizes the air between the igniter plug and the burner causing the small current to flow between the igniter and the burner. This shuts off sparking. But if there is a gap such as in the spark igniter under the porcelain, technically there still is a gap that the current has to jump and thus the stove keeps sparking. In my case changing the offending igniter plug fixed the problem.
Jul 05, 2009 | Viking VGSC366-6B Gas Kitchen Range
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Dacor Epicure EOG52 Grill Logo
271 people viewed this question
Top Dacor Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Dacor Grilling Expert? Answer questions, earn points and help others
