Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Yellow lines at the right upper screen looks like spider webs.
Also has a shade of blue at bottom left screen
  • 175 Answers
This will be your polarized filters which you cant buy anymore you will have to buy a new engine which depends on the model is between 600-800 unless you can pik up another same model of ebay for parts with a different fault but it is a common fault in these also the lgs
Posted on May 07, 2010
I have a spider in my living room looks yellow and where its legs bend there is black circles which i prosumme is there knee has yellow upper body and yellow lower body with a black dot in both top bottom...
It sound like a common Garden Spider. The spider species Argiope aurantia is commonly known as the yellow garden spider,[1][2]black and yellow garden spider,[3]golden garden spider,[4]writing spider, or corn spider. It is common to the contiguous United States, Hawaii, southern Canada, Mexico, andCentral America. They have distinctive yellow and black markings on their abdomens and a mostly white cephalothorax. The etymology of its name means "gildedsilver-face". Males range from 5-9 mm (0.20-0.35 in) females from 19-28 mm (0.75-1.10 in). Like other members ofArgiope they are considered harmless to humans.
Aug 25, 2014 | Home
Yellow Shading.
go into the menu for the color or brightness and contrast..try to change a bit at a time..
Jan 08, 2014 | Samsung LN52A550 LCD TV
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Yellow pilot flame
pilot is yellow cause its air mixture hole is blocked or you have something in pilot stem like a spider web i have had this problem on flame effect gas heaters during thier off months spiders get into pilot stem and create webs which can cause this the other reason is that the air mixture hole is blocked with carbon or something clean out to get blue flame, and an example of yellow flames in gas heaters is flame effect fires where i know a certain company cover air mixture hole on burner to get the flame more yellow and realistic looking but on a service i remove the foil they stick over hole making flames blue again, as it can cause the heater to carbon up to the extent of black glass with yellow flames
Nov 25, 2010 | Empire BF-10 Mid-Size Heater
Dirty lense, out-of-line projector?
in the power supply there are a couple of fuses they are either green or yellow they look like resisters check them with your meter one of them is going to be open replace both.
Mar 04, 2010 | Sony KP-57WS500 57" Rear Projection...
This is garbage
Send it for repair... It sounds like the Y-sus board and the upper and lower Y-drives... This unit uses the same panels as the Philips 42pf7320a so it shouldn't be that expensive for parts...
I wouldn't personally send it to Dell - instead look through the NESDA web site and locate a repair center near you and take the unit to them for an estimate.
Bill
Jun 11, 2008 | Dell W4201C 42 in. Plasma HDTV
Bad light engine I think
I had the same sort of idea..bad color engine.Hitachi paid for upgraded replacement 'cause they had had so many similar problems with this model. My warrenty had expired so they did save me about $1200 but I was stuck with the labour cost approx $300...
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Bright yellow
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
Matt
Feb 26, 2008 | NEC VT676 Multimedia Projector
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Seperated colors
this is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
