Question about ASUS A8N-E Motherboard
Motherboard I have an Asus A8N-E MB, worked fine until the other day, when suddenly I had no power to my mouse (connected to usb ), keyboard, and monitor. When I reboot, my mb has power, my heatsink fan runs, and my hard drive is running ( I can feel the hd vibrating ), any ideas ??
  • mar5lyn2 Mar 29, 2008
    Thanks for the advise, it wasn't yhe button cell battery, so I'm kinda stalled, is there a way to test the mb, and processor, short of taking it to a shop /
    Genius:
  • 1,027 Answers
I would start by process of elimination.
  1. Disconnect power cord
  2. open case
  3. remove button cell battery from motherboard
  4. press power on button to dissipate any stray voltage.
  5. re-install button cell battery.
  6. re-connect power cord
  7. power up pc.
If everything powers up ok and you get a CMOS checksum error, then enter bios set date,time etc. and go.
if the power on self test comes on and still no keyboard,mouse,video etc and no beeps. It may be your board or the processor.
Posted on Mar 27, 2008
  • Mark Williams
    Mark Williams Mar 30, 2008
    there is a way but it is a diagnostic card that fits into the computer.
    Link to information.
    I've invested in one of these cards but it doesn't catch everything.
    A emachines lost sound/front header/and 1 IDE channel but the diagnostic didn't catch it. It did catch not enough power coming from the power supply to power the video card.
Asus a8n-e m/b gets power, will not post
Hello from here you can download a manual and drivers:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NE/#download
My guees is that the windows disk is damaged or burned to fast.
Since you not get any picture on screen now the graphic card. maybe malfunctioning try to change that and see what happens.
A ps2 keyboard and mouse must be used.
Because the usb function will not work until the system is fully installed.
A restore disk does not contains a full windows its only for repair
purpose.
Good luck
Nov 02, 2012 | ASUS A8N-E Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
A8N-E, Asus MB.
A keyboard will work in the S2 port which will allow you to enter the bios.
It sounds as though the onboard battery has failed. Without a new battery, you will be able to change the bios settings but they won't be saved so you'll keep getting the error message when you boot up.
Regards
Jan 28, 2010 | ASUS A8N-E Motherboard
My keyboard and wont work and PS-2 ports will not
They may well have blown. You can use a USB keyboard and mouse - cheaper than replacing the mainboard.
ACPI on ASUS A8N-VM CSM Motherboard not working.
Can you please indicate how you turn the motherboard on if the on/ off switch is not operating?
I take it that because of the keyboard problem at boot up you are unable to get into BIOS> If this is the case then it might be very difficult to diagnose what is going on. YOu need to be in BIOS setup to check the state of the hardware.
What setup have you used to program automatic sheduling of TV program recording. Is the computer active all the time?
Not sure why you think ACPI or cmos battery might be causing the problem.
Please post a few answers that might help me understand the problem a bit better.
Jan 17, 2010 | ASUS A8N-VM CSM (00610839133826)...
Mouse and keyboard not working on it(asus a8n-e)
1)Make sure the jumper that resets the board, is on the right position based on manual.
2)Reset memory stick(s)
If this does not work, try using USB keyboard and mouse.
N Sabre
Good Luck
Nov 07, 2009 | ASUS A8N-E Motherboard
No PS/2 keyboard response on boot.
Try a different keyboard and then try a different mouse. Try unhooking the hard drive and see if it goes past the logo, if it still doesn't then go ahead and disonnect the keyboard and mouse and see if it goes past the logo screen. If it doens't go past the logo then take the memory and cpu out and blow so air onto it to make sure specs of dirt or dust are no affectng it.
you can also try different memory as well to see if it stops locking up. Otherwise if you go thru these steps and you still have the lockups, its not going to be the keyboard are mouse causing the problems, its the motheboard.
You can try a usb keyboard and it might work but that would mean you have a bad ps2 port on the motherboard and as long as that doesn't bother you then the computet will be fine.
Jul 17, 2009 | ASUS A8N-SLI Deluxe Motherboard
How to connect jumbers at asus pentium 4
Try this link
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-E/e1911_a8n-e.pdf
I hope it helps!!!
Nov 24, 2008 | ASUS A8N-E Motherboard
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
Usb ports not working
All the USB ports were working before he installed SP3 and rebooted. After that only the mouse/keyboard ports worked. Same thing happened to me. No other changes were made, so something added/change by SP3 is the culprit.
Questions is...what did SP3 do to break USB and how to fix it?
Jun 14, 2008 | ASUS A8N-VM Motherboard
ASUS A8N-E Motherboard Logo
125 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
