Question about Magellan Maestro 4250 GPS
Unit functions but no display
My GPS unit appears to be functioning as normal (voice commands work, and the unit is still navigating), but the display isn't working at all. The brightness is set to the highest level, but the display is completely dark except for several faint outlines. Because I am able to recall the approximate positions on the touch screen, I can select items and hear the menus and other features working, I simply can't see the display.
Any thoughts on repairing this would be greatly appreciated.
Thanks!
    President:
  • 1,851 Answers
Try this - if it doesn't work you have to send it to Garmin for screen repair.
1- Turn the machine off - place your thumb like this picture - Unit functions but no display - 4ac5c29.jpg
Now when the screen goes to this - push YES -
Posted on May 07, 2010
2014 F150 Lariat Sync Voice Command problem?
It sounds like it should go to the dealer for warrenty repair.
Aug 24, 2014 | GPS
Voice Command Problem
Hi sherri you are sure the connection the rear Audio/input is in the right location and the menu should have a selection under the menu/title that is a mute function
Sep 07, 2008 | Kenwood DNX5120 DVD Navigation System GPS...
Why is there no voice commands
Not all GPS units have voice capabilities. That is a function that is normally only included in the more expensive units. Most GPS unit have the capabilities to voice directions and street names, but will not work with your voice.
Mar 09, 2011 | GPS
The touch screen locks and won't function by tough but the gps works with the buttons and appears to function normally otherwise.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Apr 30, 2010 | Garmin StreetPilot 2730 GPS Receiver
I was told that 2006 dts had either onstar or radio/dvd/cd/gps system not both i spent over three hundred dollars at gm dealer for hm to diagnose this and that even though my dvd nav is factory it will...
ok this is what I just found concerning your issue.
Now this is just the beginning so Im sending this complete in sections for you.
  • Turn ON the ignition. The Cadillac emblem screen appears on the navigation radio.
  • Press the POWER/VOLUME button on the radio.
  • When the navigation disclaimer screen appears, press the I AGREE button on the display.
  • Press the NAV button on the radio. The display should show the current position of the vehicle. The navigation map should be clear and have clear color.
  • Press the voice switch on the steering wheel. Speak a valid voice command. The system should repeat your command and then perform the function.
  • Does the system operate normally?
  • Nov 10, 2009 | Car Audio & Video
    Intermittently the voice turn command does not function. When I look in tools under language there are no selection options for me. Then a couple of hours later everything seems to work fine. Any...
    You need to hook up the unit to your PC using the USB cable and run webupdater to reinstall the voices. The fact that your unit isn't showing any voice options is the cause. Perhaps they are there but corrupted. Reinstalling them will overwrite the damaged files.
    - Jim
    SHARCNET-USA
    Sep 10, 2009 | Garmin nuvi 265 Car GPS Receiver
    Setting up voice recognition on my 920t
    voice recognition should be set up by default on the unit you describe. in order for it to go into voice recognition ou need to do navigate to the spoken address
    Dec 27, 2008 | Tomtom GO 720 GPS Receiver
    Maestro 4040 code
    RE: Voice Command...
    I havent seen the TigerDirect ad up but:
    1: Voice COMMAND is a $99 OPTION= It allows YOU to speak to the unit- (Speak commands TO THE UNIT, EG= select options)
    The unit does NOT come with this feature enabled....
    That said the unit DOES COME with SayWhere Text to Speech , that talks to YOU. (Hear when to make each turn, including the street name)
    So to recap= 4040 talks to YOU, but to command the unit (You talk to the unit and it perform a function) it costs another $99
    BTW: I just got my 4040 today
    Firmware 2.36, Maps #27 (3rd Q-2006)
    While RUNNING a simulation of a route- IF I click on a POI and ask the unit to figure a route to the newly selected POI... the unit stops responding- then crashes, then reboots.
    Not happy--- Sounds like to me the CPU can't handle the extra loading...
    Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
    GPS Use
    Hye! here's how you can take care of this issue: Dowload google maps from the web (for windows mobile) & install it on your diamond. In order to use GPS on this phone, your internet/gprs connection must be functional; without netwrok connectivity you cant use GPS on this device as it does not have the map interface on its chip (& cant be loaded later too). It just has a light GPS transceiver which in presence of a mapping software (such as google maps) can show your position on the globe & in some countires can also navigate you. After installing google maps, make sure your internet connectivity is on and then work with google maps 'USE GPS' & 'My location' or 'Navigate' functions ... enjoy!
    Aug 25, 2008 | HTC Touch Diamond Smartphone
    Garmin 2610 freezes-up
    CHECK THIS OUT IF SCREEN CLEANING DOESN'T WORK.
    Regarding the screen jitter, believe it or not, the infrared port is causing the issue. If you disable it through settings inside the unit your issues will go away. The sun basically destroys the infrared sensor and the unit "thinks" a button on the remote is getting clicked continuously.
    Nov 03, 2007 | Garmin StreetPilot 2610 GPS Receiver
    Magellan Maestro 4250 GPS Logo
    142 people viewed this question
    Top Magellan GPS Experts
    Will Halftowaite
    Are you a Magellan GPS Expert? Answer questions, earn points and help others
