Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer door open for 5 minutes now won't cool
I was loading my GE Profile side-by-side and arranging the freezer's contents, so the freezer door was open for about 5 minutes. Since then, the temperature of the freezer has continued to increase. The read-out on the refrigerator showed the freezer at 0, then I noticed it was at 1 degree, then 5 degrees, and now 8 degrees (the refrigerator temp is also rising, but it still seems cool). The ice started melting and I had to take the whole dispenser out because it was dripping on the rest of the food. I don't want to keep opening the fridge or freezer to see if it's getting cooler, for fear I'll let all the cool air out. What should I do so I don't wake up to a freezer full of thawed food in the morning?
  • ali_ackerman May 07, 2010
    Update: after keeping the fridge/freezer doors closed all night, the unit finally got back down to temp. It seems like all of the contents are still intact, but there's a lot of ice on the packages from the dripping ice dispenser earlier in the evening.
    The temp control is on the top of the fridge side - unless there's some other hidden control, I don't think I would have bumped it. If it was stuck in defrost mode, how do I stop it? It also has periodic issues with the water dispenser not working, but if I open the freezer door (the side where the water dispenser is) for a minute, then close it again, the water will start to flow after a few seconds. At this point, I'm wondering if I should even keep the fridge.
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
PABLOCSA
  • 1124 Answers
SOURCE: GE PROFILE PSW26SGRB SS
This is a problem of thermostast which is not working properly. Replace or fix it and this will be fx your issue.
Posted on Oct 13, 2008
  • 33 Answers
SOURCE: Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Posted on Nov 29, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
aasc
  • 1606 Answers
SOURCE: GE PROFILE SIDE BY SIDE MOD PSS25MGN - NOT COLD - FOOD THAWING!
Sounds like a main control board defective .The one on your refrig WR55X10552 , is on a recall list .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
The new part number is WR55X10656 . I would suggest calling GE , to have them come out and check , as this part and labor , should be covered , as stated by the letter .
Posted on Nov 08, 2009
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
Why is GE Profile Bottom Freezer Refrigerator not cooling
Check manual for proper setting.
Check compressor running condition. (set to lowest temperature and let the doors open. the compressor must run contineously. Feel if it is cooling up. If so then close the doors and observe the compressor running behavior. It should run for minutes before the compressor stops.
If compressor is running but no cooling effect it is either leakage of freon or loose compression. let it be checked by a certified technician.
If compressor is not running at normal temperature check your thermostat and OLP (over load protection) relay. Both must be closed circuit.
Aug 13, 2014 | GE Refrigerators
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Freezer door hard to open for about 3 minutes
This is normal and nothing to worry about. The warm air that enters the freezer when the door is open simply cools and causes a pressure drop in the freezer whioch makes the door hard to open for a while until the pressure equalises. It at least proves that you have good door seals!
Sep 10, 2009 | GE Profile¿ 42" Built-In Side-by-Side...
GE Profile Arctica freezer door not sealing properly.
Loosen the hinges on top of the door left side, . lift or lower the door till it is level with the top of the unit. now do the other door. now look at the line between both doors, and compare the gap at the top and bottom . adjust once more time if needed. clean the metal and the magnet with windex then put weson oil on a clean towel and wipe all the way around each door.. hope this was helpfull to you.... Sawdust46
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ge armoire style condensation on freezer door
the condensation is due to a small amount of cold freezer air getting past the gasket. Warm the entire gasket up for a few minutes with a hair dryer and then close the door and keep it closed for 30 minutes. That will reshape your gasket and solve your problem.
please rate this answer as a fixya!
Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
134 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
