Question about HP LaserJet 1000 Printer
Laserjet 1000 keeps warming up and prints blank nonestop
My printer status shows "warming up" and when i send print command it prints blank page continousely, doesn't stop!!!
plz help ...
    Sergeant:
  • 313 Answers
Check your cartridge...
is it new...?
Posted on May 07, 2010
Printer Printing blank pages
Does it print at all? Have you tried a demo print? menu->information->print demo
Is it printing additional blank pages are all pages blank?
The first thing to check would be the toner.
Try printing out the supply status page (menu->information->print suppies status).
You could also try diagnostics-> PQ troubleshoot.
John
Oct 10, 2011 | HP Color LaserJet 5550hdn Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Blank page problem
press and hold the green button for 5 seconds to generate an internal test print... does it print? If it does its a driver issue... if it dosent check your toner ctg remove and reinstall
Jun 05, 2010 | HP LaserJet 1020 Printer
I have a problem with my hp colour laserjet 4650 any i turn it on it shows 49.1e19 can u help me.
A critical firmware error has occurred that has caused the processor to abort the command / operation.
This can be caused by corrupt data, invalid print commands, or electrical noise.
In some cases noise can corrupt data in the cable to the printer, or your PC could be sending garbage to the printer.
Could be poor quality cables, poor connections, or network card jabber.
Can also be a faulty Formatter board, though this is fairly rare.
Power cycle the printer with the data cable disconnected and try to print the config page, from the <Information> menu.
OK?
Then reconnect data and try to print a simple file, ie, a blank Word page with perhaps the word test typed on it on it.
You may have a faulty DIMM in the printer.
Dec 15, 2009 | HP Office Equipment & Supplies
Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Oct 20, 2009 | HP LaserJet P3005n Printer
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
437 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
