Question about Kitchen Ranges
Kenmore stove with self cleaning oven, keeps going through a cycle of the door locking and unlocking and F1 appearing on the screen. The oven controls do not work
  • 821 Answers
Helllo,If you have a oven that will not unlock after the cycle you have a few things you can try.
First make sure that you wait long enough before you try to open the oven. If it has not cooled completely it will not open. Do not run a clean cycle when you do not have the time to let it cool completely before you need it. Sometimes if you cycle the power to your oven off and then on again you can reset the oven and it will open. Turn off the breaker to your oven for a good minute or two before reapplying the power again.
If this fails to work then check your manual for instructions or to get a factory service number. They should be able to give you the information you need to open your oven.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
OR
the f1 code is a clock failure and you will need to replace it.after this is done,your oven will work as perfect as it was.
WISH YOU GOOD LUCK,
TAKE CARE.
Posted on May 07, 2010
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Door is lock
How to unlock Kenmore oven - YouTube
? 1:07
www.youtube.com/watch?v=xnwnLi8Ld5I
Jun 30, 2013 - Uploaded by Imi Chitterman Kenmore oven lock and unlock after self cleaning. ... What should I do to get my oven door open please? I pressed the start button but it didn't ...
www.partselect.com/.../Range-Stove-Oven/Door-Will-Not-Open-After-S...
If the door will not unlock at the end of the clean cycle then you may have a problem with the oven temperature sensor. Most electronic control ovens will display ...
Nov 05, 2015 | Kitchen Ranges
After cleaning the outside surfaces of the stove, the oven door is locked and does not unlock if we push the stop button. Display reads LOC. No self cleaning cycle was initiated. The stove is a Kenmore...
What about child lock? Read user manual or try holding button for 10 seconds, might be two at once.
(I bought a $200 control board and travelled 150 kilometers for that one....)
Oct 15, 2013 | Kenmore 49043 Electric Single Oven
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
