Are there gas lines located next to houses that dont use gas in the house. when i was rotortilling a foot down all of the sudden i smelt gas and it was right next to the houses foundation
    Genius:
  • 1,040 Answers
Dear Smgiannetti,
Yes of course...... the gas line works same as water line.... Company installed them besides the road, when anyone want the gas then they just connect the house with that gas line.........
Posted on May 07, 2010
Car suddenly died. checked battery, i think it's the fuel filter. I have no idea where it is located.
The fule filter is located in the engin compartment. Remove the air filter, and the compartment that houses it. Looking towards the fire-wall, and slightly down. The fule filter is located in the lower left. I suggest you purchase the fule filter first and this will help you find it.
Use A LINE WRENCH too remove the bottom gas line. The top bolt can be removed with a scocked( all of these are Metric) The bottom one is a ******!!!
Goo lunk
Jun 28, 2011 | 1994 Mitsubishi Expo
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
There are 3 houses each have to be be connected to the gas co, the electric co and the water co without the connections crossing paths
It is somewhat confusing with the information provided. So, 3 houses, and you need to have the gas, water and electricity come into the house without these 3 utilities crossing each other. I am an electrician and I can give you this solution from my experience. I rather like to have all the utilities enter a house at the same location. This gives me an area in the house where I have everything including telephone and cable enter and this allows me more space in the house because the utilities are not taking space in other rooms. So, water is usually installed from about 8 feet down in the ground. Electrical can be buried at 3 feet and the gas is the tricky one. The thing with gas and electrical is this. If you cross a propane line with electrical the electrical must be above the propane line by a minimum of 1 foot. Propane is heavier than air and will flow down in to a trench so electrical is above. If crossing natural gas, then the electrical is below the gas. Natural gas rises. Water is not a problem for either. I would check with local regulations for exact measurements and procedures.
Mar 08, 2011 | Garden
Repar water pump on 1996 35hp johnson
VERY EASY REPLACEMENT
REMOVE PHILIPS HEAD SCREWS THAT HOLDS THE PLASTIC WATER STRAINERS ON THE FOOTOF THE MOTOR,
NEXT LOOSEN THE HEX FITTINGS 7/16 OR 1/2 WRENCH SIZE THAT WERE COVERED BY THE STRAINERS
NEXT REMOVE THE 2 STAINLESS STEEL BOLTS THAT ATTACH THE FOOT TO THE LOWER UNIT.. BOLTS COME OUT FROM THE BOTTOM,, NEXT LOOSEN THE NUT ON THE FRONT OF THE FOOT FACING THE TRANSOM LEAVE A FEW THREADS TO HOLD THE FOOT SO IT DOSEN'T FALL. NEXT WIGGLE AND SHAKE THE FOOT
TO LOOSEN IT FROM THE LOWER UNIT . NEXT STEP REMOVE THE NUT WHILE HOLDING UP ON THE FOOT THEN SLOWLY REMOVE FOOT ASSEMBLY WITH DRIVE SHAFT.
NEXT REMOVE THE O RING FROM THE FITTING THEN REMOVE THE FITTING FROM THE SHIFT ROD THERE SHOULD BE A BIGGER O'RING ON THE SHIFT ROD NEXT TO THE WATER PUMP HOUSING . REMOVE BOLTS HOLDING WATER PUMP HOUSING ON THE FOOT ASSEMBLY LIFT OFF HOUSING LOOK FOR IMPELLER KEY TO FALL OUT . I RECOMMEND REPLACING IMPELLER AND HOUSING AS A KIT . INSTALL IN REVERSE ORDER .
IT'S A PIECE OF CAKE ...
Aug 06, 2010 | Boating
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Why is my aux heat light on and em heat light on at the same time i smelt a gas odor in the house and we been running the heat for a few days now i never smelt it before,i mean the lights are off now and...
Do you heat with Gas? typically unless you are dual fuel the em heat is electric heat and you may be smelling dust burning off the coils. if its gas then turn it off and immediatly call your gas provider or fire dept, If you dont know then i would get a qualified service company out to look at and explain the operation, as to make sure its working properly and effiently as possible
Oct 18, 2009 | Honeywell TH4210D1005 Heater
96 chrysler Lhs when i take my foot off the gas
idol air controler keeps car running at idol speed ,you can take it off and clean it with throttle body cleaner to get carbon off its located on throttle housing ,if this works or improves your problem at all get a new one...
Oct 01, 2009 | 1996 Chrysler LHS
I need to know how to change the fuel filter in a 98 gmc sonoma v6.
It is located under the truck on the driver side inside the frame rail remove the 12 M bolt to get the holding clamp off next get two plastic baggies and two rubber bands and a catch pan. Do this where there is no items that could cause a spark or a gas water heater is at that could ignite the gas. Now pull the U clamps out of each end of the filter, if you brake them it is ok the new filter will come with new clips there are two type of fuel filters some may have 2 lines others have only one but you can't get them wrong. Pull out the plastic pieces and put baggie on the fuel line and put rubber band on to keep it from leaking gas do this to all lines. next install the lines one at a time and reinstall the clips. Be sure to slide out the old filter from the housing then reinstall back on the frame and tighten the bolt down. Next Get in truck and turn the key to the Run position (Not start) then off do this 10 times this will prime the pump and fuel lines then try starting it, once it fires up it may run rough for a minute but should smooth right out. hope this helps.
Sep 30, 2009 | 1998 GMC Sonoma
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
