Question about Vtech IA5854 5.8 GHz Cordless Phone
I tried to locate a lost phone and now the phones don't work and the display reads "not registered" what do I do to fix this?
  • 343 Answers
Try to restart
Posted on May 07, 2010
HandsetS #2 and #3 work properly. Handset #1 has a display screen with correct datet and time -- but no dial tone, How can I fix this?
This sounds like Handset #1 has lost its "registration" with
the base. De-registering & re-registering is often easy.
First, be sure the handset battery is well charged as a
weak battery will interfere with the registration process.
Then try this ( 'works for the D1680, D1481, & similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
within ~30 seconds the handset should display
a "Handset #" and be good to go.
Nov 26, 2015 | Uniden DECT 6.0 Cordless Telephone...
Having problem connecting: handset out of range
This sounds like the handset has lost its "registration" with
press [SELECT]
a "Handset #" and be good to go...
Oct 05, 2015 | Uniden DECT 6.0 Cordless Phone
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
Out of range or no pwr at base
It sounds like the handset has "lost" its registration with the
base ( or a replacement handset is being introduced ? )
Either way, the handset displaying "Out of range..." is now
orphaned and must be deregistered and then re-registered
to the new/current base.
enter *331734# (menu)
is still blinking.
Good luck !
Oct 14, 2011 | AT&T TL32100 Cordless Phone
We have Panasonic KX-TG6531, 4 handset. One unit is not working and shows on the screen: base no power. We lost a brochure for this phone and don't know how need fix this problem. Would you help us,...
Hi.
Even though You did not say how old these units are.?.this is a specific battery problem...
you can test it..take the other ones battery and replace problem unit's battery you will see that it will work..You can buy new battery at any Super stores.try to take one with warrant on it..
since you stated that you need an operating manual. pls visit the URL below to download one.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg6531.html
Jul 11, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
My idect D1i phone keeps asking me to register
Hi , The phones which keep saying Register mean that they have lost the coding for the Base. To re-code them all you do is
press the menu button,
Press down Button 3 times until Setting comes on the screen,
Press the Button Phone/Ok,
The Display should display HANDSET SETTING,
Press the Button Phone/Ok ,
Then Press the Down button about 4 times until Register Comes on the screen,
Enter Base pin ( 0000 )
The Display will show REGISTER IN PROGRESS,
then immediatly press the Handset Locator Button on the Base and hold it in until you hear a tone.
Thats it , the screen should display Register Done.
Mar 06, 2010 | Lands Phones
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
How tomake outgoing calls with my american telecom digital cordless phone model#ra23634H
Thuis was hard to find but it worked for my ra2364hh's
note the phone stopped working in "tone dial" after 2 months and now functions with "pulse dial" only.....
Registration The handset and base will be pre-registered with a digital security code identification, which is stored in the phone’s memory, so that your phone will be ready to work right out of the box. However, your phone also has a procedure to allow you to re-register in case the link is lost accidentally. Enter menu, press the key - Select REGISTER and confirm PIN CODE will be displayed, enter the PIN code (the default value is 0000) and confirm. SEARCHING will be displayed while your handset is in registration mode Press and hold the Page key for 3 seconds on the base until the “In use” LED is ON, putting the base in registration mode SUCCESS will be displayed. This means the handset has located the base, and will get a handset number from the base that displays after the handset name for internal calling. If the handset does not locate the base, FAILED will be displayed and it will return to the non-located display mode that displays BS SEARCH with the antenna icon flash. Try again and check that you are not in an environment with interference. Note: Your base can register up to four handsets. If you have more than one handset, repeat the above steps to register each new handset.
TESTED IT 2 minutes ago and it WORKS.....
tony
Feb 23, 2009 | Lands Phones
I have a panasonic KX-TG2336S cordless phone and when you try to make a call the handset displays "no link to base". Can this be fixed or is the phone shot?
Just in case you don't have a manual
http://service.us.panasonic.com/OPERMANPDF/KXTG2336.PDF
Page 55 lists your trouble and gets you to page 49. You take the bandset and base, press the locator button on the base and then press the flash/recall button on the handset until Handset Registering appears on the display. If it beeps one time, wait 20 seconds and it should register. If it beeps 3 times, keep trying.
Carl
Jan 18, 2009 | Panasonic KX-TG2336S Cordless Phone
Vtech IA5854 5.8 GHz Cordless Phone Logo
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
