Question about Dometic Rooftop RV Air Conditioner
No water comes out of ac - Dometic Rooftop RV Air Conditioner
  • 306 Answers
Good.
Posted on May 07, 2010
Just noticed water coming from underneath the car when reversing back there was a trail of water
If there is antifreeze in the water, then it comes from somewhere on the engine. An inspection of hoses , radiator and freeze plugs is in order. If there isn't antifreeze in the water, then it is most likely condensate coming from the AC case. This is normal if the humidity is high and you use the AC a lot.
Aug 30, 2016 | Cars & Trucks
Litters of water accumulating in the foot well of the rear passenger side seats which can soak your feet. There is dampness in front and other side. We have no idea of where this water is coming in from....
Depends on where the water is coming from. The 2 most often causes of water buildup is either the heater core is leaking or the AC condensate drain tube is blocked. If the heater core was leaking, you'd smell antifreeze or see steam coming from the vents while driving. The AC condensate drain tube lets condensation water to drip overboard from the housing. This tube is on the bottom of the AC case on the firewall side under the hood. Sometimes you need only pinch it to open it to drain out the water buildup..
May 10, 2017 | 2008 Ford Fiesta 1.4
AC water leaks inside car, 2002 mercury sable
You probably have two different issues here.
The water on the floor is usually caused by a drain tube being stopped up. The tube is supposed to let the water drain out of the car and onto the ground. It should be on the bottom of the firewall or below the floor.
You would need to have the computer scanned for trouble codes to find out why the check engine light is coming on.
Jul 19, 2012 | 2002 Mercury Sable
I have a 1993 Ford F-150 that has water dripping down the firewall, under the hood, when the engine is running. The water is coming from inside a circular plastic piece located under the hood - just under...
Water that comes from the AC Evaporator is normal and necessary.Part of the A/C process removes moisture from the air it is cooling, via condensation.
Feb 11, 2011 | 1993 Ford F150 SuperCab
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Condensate blown out of the AC vents in front of passenger seat
U need to crawl under the car and clear the ac condensate drain, it is a rubber pipe on the passenger side that sticks out of the bottom of the engine firewall, they get clogged and water builds up in the ac and this problem happens.
May 14, 2009 | 1999 Mitsubishi Montero
Water comes out through AC drain
its filled up the bottom of the box and its just enough to blow out when running
Oct 07, 2008 | 1996 Pontiac Grand Am
Leak in rear of car, the leak appears to be linked to ac. no leak detected unless ac is on high. if on low there is no leak I have a water leak coming from the front passenger side of the car. It is a...
this water is condensation . it comes from the evaporitor on the dash of the car. and there is a tube from the ac system that is there just to remove the water build up. only leaks you need to be worried about would be oil or antifreeze
Sep 11, 2008 | 1997 Lincoln Town Car
Dometic Rooftop RV Air Conditioner Logo
74 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
