Question about Apple safari
Whenever I log on and open safari the little colored circle thingy appears and Safari is unresponsive. As soon as I force quit and open it again it works. After 2o some reports to Apple I've quit reporting and the problem persists. I have a 2009 Macbook with OS X 10.5.8
    Sergeant:
    Champion:
  • 265 Answers
Have installed updates? If ye, then use Firefox or Gogole Chrome browser.
Posted on May 07, 2010
How to unfreeze safaris when force quit won't work
Hi!
Force quit should force Safari to close. However, if your system is unresponsive-- a restart may be required.
Hope this helps!
Feb 25, 2015 | Apple Computers & Internet
Help, I have MacBook Air and it won't install new require Flash version....it keeps telling me I need to quite safari but I don't have safari open...hours and hours of wasted time.
Camille,
Although you might not have Safari open where you can see it it might still be running as a process. Open Activity Monitor and select Memory, scroll down the list of items using memory and see if you see anything related to Safari still active in memory. If you find something, double click on it and another window comes up with information about the process. Select at the bottom quit. There are two options to quit first is quit second is force quit. If quit alone does not remove the process then you will have to force quit the process. A word of warning although this is an easy way to quit processes that are not responding, or not closing be careful some processes are system processes and if shut down forcibly can cause the system to lock or crash. I have not heard of any damaging effects from this besides data lose in apps that were open but always be careful.
Nov 02, 2014 | Computers & Internet
Change homepage on mac
Your homepage is the page that normally appears when you first open Safari.
  1. Open Safari if it is not already open.
  2. Choose Safari > Preferences, and then click General.
  3. Do one of the following:
    • To use the page in the current Safari window or tab, click "Set to Current Page."
    • To use another page, type its address in the Homepage field.
    • To use a blank page, delete the contents of the Homepage field so that the field is blank.
  4. If you also want the homepage to appear whenever you open a new Safari window, choose Homepage from the "New windows open with" pop-up menu.
Good Luck!
Jul 03, 2014 | Computers & Internet
Safari does not work after I installed Safari 6.1 on my OS X 10.8.5 MacBook Pro.
Safari fix after upgrading OS maverick or Yosemite
Safafi not responding after upgrade of OS? Follow the simple stemps below:
Click on the apple logo in the left corner of your mac
Close your safari
Open system preferences
Open network
Go to Location drop down menu from network page.
select edit locations
and change the location from automatic to any other option you may need to create a new one here select the + symbol and name it " temp delete me"
select done
select apply
- the wireless network will be disconnected
ensure you are on you select wife from the left column or Ethernet if that is how you are connected (by cable)
Go to network
Goto Location again and select edit
Select the new network you just created (temp delete me) and select the - (delete symbol)
Select the automatic network again
Now select apply
- the wireless network will be restored again and you can now use safari.
this worked for me after upgrade to yosmite and it also worked on the upgrade to mavericks! I would of expected apple to of resolved this problem.
I hope this helps someone.
i did post pictures above but they are not showing on this form.
Nov 05, 2013 | Apple safari
Safari page will not open
  1. Try Command-N.
  2. The window may be open but moved nearly out of view. Tap the F3 button, do you see a Safari Window?
  3. Safari may be frozen, from the Apple Menu go to Force Quit and see if Safari is listed, if so it may be red and say "Not Responding" Select it Force Quit, Confirm. Try reopening it now.
  4. Restart if all else fails.
Apr 02, 2012 | Apple safari
Safari would not quit and would not let me shut down computer
if you are using Mac that can be easy to handle.
Click on finder at the bottom and click on Apple at the top and choose force quit
then choose safari and force quit
relaunch finder! you are done!
If you are using PC press CTL ALT Delete simultaneously and choose end tasks choose safari that will close safari!
Sep 11, 2011 | Computers & Internet
Cannot quit safari before beginning this update
Thank you for contacting Fixya Support
In order to quit Safari before updating, if the web browser cannot be closed normally, you can simply perform a Force Quit by pressing the Apple Command Key + Option Key + the Esc Key and this will bring a window up displaying all currently open applications including Safari.
If you see that Safari is listed in that window, it should have a "Not responding" tag next to its name.
Simply click on the Safari name and press the Force Quit button and it will close out the Safari application.
If you require more information or assistance with this issue, please don't hesitate to reply to this post.
Regards,
-Mactechtrainer
Jun 26, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Problem to close safari excused my speeling
Safari & Force Quit? Is this a mac? Sometimes Safari acts up if the Computer Clock is not set because of news updates and so on..... Also would hurt to run a permissions repair in disk utilities to help clean up any errors...
Apr 25, 2008 | Computers & Internet
Safari Browser makes the 15" PB G4 unusable
I would go info safaRI, and empty cache and reset safari, then go to software update and see if there is an update. I would also check to see if your OSX is up to date. If you are not running 10.4, i would update to at least 10.4.9. If you are running 10.4, i would get a dvd copy of 10.4 and perform what is called an archive and install.
http://docs.info.apple.com/article.html?artnum=25392
http://docs.info.apple.com/article.html?artnum=107120
Keep me posted.
Nov 13, 2007 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple safari Logo
90 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
