Question about Garmin nuvi 200W GPS Receiver
Nuvi 200W GPS power supply will not stay plugged in
Nuvi 200W GPS power supply will not stay plugged in my 12 volt cigarette lighter
  • 1 more comment
  • Harry Drew Mar 31, 2008
    I have the same problem. Maps don't power up. The unit starts, then shuts off. If I knew the garmin dies within a year, I would have never bought one.
  • wood wood Apr 13, 2008
    it goes to loading maps and then it shuts off.
  • mulvag11 Jun 27, 2008
    I am also having this problem - cant find the original box or info for the unit or receipt so am going to try going to halfords for a new power adaptor - have tried changing fuse in tip of exiting adaptor, all my other adaptors are working for things like ipod transformer and 3-way sockets and adaptor to power up mobile phones/blackberry so it is not the power from the car that is at fault
    Problem Solver:
  • 9 Answers
Hpd367 - If your Garmin has died within a year then call them for an RMA number and they will repair/replace it.
Tel 0808 238 0000
Moscow Nell - I had the same problem and got an adaptor from Halfords for about £5.
Posted on Apr 04, 2008
Won't come on even when connected to a pc
Why should it? Connect it to something that is 12 volts DC - like the cigarette lighter receptacle in your car. A PC is not the proper power source or voltage.
May 15, 2016 | Garmin nuvi 200W Car GPS Receiver
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
How to cargs battery
No you don't unless of course your power supply does not work unless the key is on, otherwise plug one end into the 12 volt supply, the other end into the gps and happy charging.
Apr 02, 2010 | Garmin nuvi 200W GPS Receiver
Shutting off automatically or switching to battery despite being plugged into cigarette lighter
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Aug 09, 2009 | Garmin nuvi 200W GPS Receiver
Garnub Nuvi 500 power source
I have checked around but can't find anything smaller than 12 volt booster pack, the type used for boosting car batteries. They have a cigarette lighter outlet. They are quite heavy to carry around after a while but they can come in handy depending on the circumstances.
Aug 02, 2009 | Garmin Nuvi 5000 GPS Receiver
Tottom direct power supply
No, it will fry the unit!!!
You need the cigarette lighter adapter to bring the voltage down to 5V. More than 5V will fry the One.
Apr 02, 2009 | Tomtom ONE 3rd Edition GPS
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
Garmin nuvi 12 volt power cord
Could be the cord or your car plug. Does it fit snug? I have a 1996 Acura TL and the way the cigarette lighter is designed, I have to give it a bit of pressure so it makes good contact. try your unit in another vehicle and see if that solves the problem. If so, it's your car's cigarette lighter connection.
Jul 21, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
228 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
