Question about Acer Aspire 6920-6621 Notebook
I have an Acer 6920 laptop, for some reason the screen has lost all colour (now only black and white). it is colour during the boot sequence but just after loading the desktop icons it goes black and white. when i disable the NVIDIA 9500m display adapter colour returns but i lose screen resolution. i have also uninstalled and reinstalled the driver but still no luck. any ideas? thanks, Darren
  • darrensegal May 11, 2010
    Vista is the operating system. NVIDIA GeForce 9500M GS. NVIDIA drive version = 8.17.11.9562.
    i uninstalled the drive then had it do an auto update. the problem persists.
    also;
    - the volume must be muted (audio panel, left side) to hear - ie, the button's function has been reversed.
    - i can no longer put the computer to sleep at all, neither by the Start window or 'Fn + Zz(F4)' combination.
    - the brightness can not be controlled by the 'Fn + Arrow' keys
    What is wrong with this ACER - I'm thinking that this might be my last ACER!
I have an aspire 4520 laptop and it's been a long time I never used it because the keyboard is broken. One day try to open it and the screen was white or sometimes blurs. what should i do?
Posted on Feb 28, 2011
My Acer Aspire 5335 turns on but then just goes to a black screen with a flashing white "underscore". Any ideas what could be wrong?
It sounds as though you have a corrupt boot sector, you may be able to access a system restore but THIS WILL WIPE YOUR DATA. Usually accessed through clicking alt and F10 during the initial boot sequence. Hope this helps
Feb 18, 2013 | Computers & Internet
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
Acer aspire 6920 won't boot up
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 30, 2012 | Acer Aspire 6920-6422 Notebook
Hi, Cant boot up my Acer 6920, regular start up or in safe mode. Just takes me to a black screen.
Hi. Try to perfrom power drain to your netbook. Take out the battery then unplugged the power adapter. Press and hold the power button for 30 secs. Put everything back in then turn on the computer. If same problem will happen then you need to contact ACER and have your computer srviced for LCD problem.
Oct 11, 2010 | Acer Aspire 6920 Notebook PC
How to boot my laptop to its factory setting. its an acer 6920 n it has vista
Take a closer look at the boot up time to find something like
F9 to restore
and press that key during boot up. CAUTION you will loose all your data, so take back-up of your files and write down your passwords and other settings.
Stelios.
Feb 21, 2010 | Acer Aspire 6920 Notebook PC
Acer 6920 Won't boot... Neither post... But lights and fan start.
sounds like the integrated video on the mother board went out there is a company in florida that will fix it for about 150 dollars but you have to send them your computer the list on ebay for mother board repair
Oct 06, 2009 | Acer Aspire 6920 Notebook PC
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Acer 6920 LCD Screen damaged
The screen is impossible to repair if its cracked. Getting a new LCD isn't that expensive but only if you know how to replace it. Getting one from manufacturer is around 130. but there is an ebay link on the bottom you can get one for 70 or so with shipping.
This link shows you how to replace a LCD screen. even tho its not your model but is very close to how yours look.
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-acer-aspire-3620-laptop/
This is the link to a new LCD screen for your laptop.
http://cgi.ebay.com/NEW-ACER-ASPIRE-6920-LAPTOP-LCD-SCREEN-16-WXGA-GLOSSY_W0QQitemZ350199312405QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5189817015&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
May 12, 2009 | Acer Aspire 6920 Notebook PC
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 6920-6621 Notebook Logo
274 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
