Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
No picture I originally thought the TV had no picture. But after looking at it at an angle the picture was there. If you turn on the TV you can get a menu for as long as 30 sec & then the screen goes black. If I turn the TV off and right back on I get the black screen again. It acts like the brightness is turned off. Like I said before the picture is there it is black but you can see something there if you look at a sharp angle. Any ideas??
  • 175 Answers
It will be the fluros which are hard to find if u can find them not many companies make them and also they are a pain to replace the whole tv has to be pulled apart
Posted on May 07, 2010
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I HAVE A TOSHIBA 37AV502U, THE PROBLEM I'M HAVING IS THAT THE COLOR ON THE PICTURE IS WRONG, IT'S A BIT HARD TO EXPLAIN BUT IT LOOKS LIKE THE PICTURE WAS TYE-DYED OR SOMETHING, YOU CAN SEE THE CABLE...
IF THE MENU LOOKS CORRECT THEN IT WILL BE A MAIN BOARD FAILURE IF THE MENU LOOKS GOOD THEN IT COULD BE T-CON BOARD FAILURE. CHECK ALL CONNECTIONS BEFORE AND AFTER THE PARTS ARE REPLACED.
Dec 17, 2010 | Toshiba 37AV502U 37 in. LCD HDTV
Hi, I just bought a new lcd tv and the picture is great when you look straight at it, but if you look at it from an angle it turns like a photo negative. Please help
Hi nothing you can do about that - sounds reminiscent of the old school LCD computer monitors/ laptop screens. the LCD technology has advanced significanty to170 degree viewing angles to all but eliminate this artefact.
Aug 10, 2010 | Televison & Video
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
Apr 12, 2010 | Vizio GV42L 42 in. LCD Television
No picture from my xbox 360 to my tv??
It is the solder under the GPU chip. Same as the 3 red light problem. YOu can send it to us if you want it fixed.
xbox360fixer@verizon.net
Thanks
Jan 03, 2009 | Microsoft Xbox 360 Console
LG rear projection convergence issue, can it be fixed without replacing parts?
I'd love to help, but without a make and model, littel can be said. Also, when you attempt to turn the set on, does the standby light blink at all? If so, how many times?
Thanks,
Dan
May 08, 2008 | Televison & Video
Poor picture quality from 130 degree viewing angle on my LCD tv
It is unfortunate but "off angle" viewing will compromise the picture especially on larger TV's and LCD. Off angle viewing can come from the vertical axis or the horizontal, as you described. This is clearly illustrated with a laptop computer. Adjust the screen forward and back (vertical plane) and you will see very clearly that you get the brightest picture in a very small amount of range of the screen. Likewise, viewing from the side compromises picture as well.
I also don't believe that the delay is indicative of any problems.
Apr 10, 2008 | Televison & Video
Sony wega 27'' crt hdtv issue DZ-29m61
object in the picture look small,tiny and elongated especially when viewed from certain angles.Worse,the picture seems to have a horinzontal bend towards the bottom of the tv screen it is due to malfunctioning due to technical defects in TV. YES the problem is in vertical output section of your TV. IT is due to some electrolytic capacitor failure in tv. if it is replaced by the same value as it is your problem will be solved. hope this will help. good luck. it is a common problem & not major.
Oct 08, 2007 | Televison & Video
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
161 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
