Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What is the error F1 or Fl - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 20, 2010
What is mean error code FL
Error Code F8 E1, LF, or LO FL all indicate that no water is detected entering washer after 13 minutes. ... If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive.Apr 24, 2018
F8 E1 or LF or LO FL Error Code in Display - Whirlpool Home ...
producthelp.whirlpool.com/.../F8_E1_or_LF_or_LO_FL_Error_Code_in_Display
See the videos
error code FL Google Search
Jun 11, 2018 | Washing Machines
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Hello my is David a have a problem with my kenmore elite oasis 27062 when i start off to wash it rinse the water to cloth then it lock it self but when enter the spinning phrase it stop it display a error...
the error code is an F1 . your washer is made by whirlpool and for them they had a recall for any washer that had that issue. what you will need is a new main control board and wire harness. here is the rework page whirlpool gave all of the service companies. http://servicematters.com/docs/doc_main.htm hope this helps. they should cover the cost of repair. one thing to check before you do all this is with no clothes in the washer spin the tub by hand just to make sure it spins freely. cause if clothes get between the inner and outer tub it can cause the F1 error code as well.
Jul 03, 2010 | Washing Machines
I turn on the top load washer ,it starts to fill
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Oct 13, 2009 | Kenmore Washing Machines
What does F1 means
Could it be FL?:
FL Flood condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore He2Plus 110.47511701 FL Washer F1 code and
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 11, 2009 | Kenmore HE2 Plus Front Load Washer
Will not complete cycle error ''FL'' or ''F1'' displayed
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Jun 13, 2009 | Washing Machines
Oasis he washer error code F1 or Fl
Apr 07, 2009 | Kenmore Washing Machines
I received an error on my Kenmore Elite Calypso washer of FL or could be F1 and I did not receive a manual with the washer to look it up. Can you help me fix this? Thank you
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
The problem could be caused by a blocked or bad water pump but also there is a back up valve or flap in the drain assembly that also sticks and some times causes problems with the FL Error code . If you remove the back up valve flap this can some times clear the problem.
There seems to be a lot of problems of this nature with this washer on the web. It seems there is aclass action law suit between the consumer and Whirlpoos/Kenmore. The phone number to call to get more information. 1-877-567-4297. There is also have a website to download the claim form http://calypsosettlement.com. Depending on when you purchased your machine you might be able to file a claim.
also if you don't qualify for that there is a replacement motor that was designed for the unit that works better than the old one but still seems to have trouble occasionally;-
The pump part number of the pump is 8054954. Here's a direct link:
http://www.partselect.com/PartSearchResult.aspx?PartNum=8054954
It's apparently easy to change the motor, so give it a shot. It's cheaper than a new washer (and partselect.com is even cheaper than Sears, who want $120 for a new pump... and another ~$100 to send someone out to install it!!).
Aug 19, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
