Question about Miller RENEGADE 180 WELDER GENERATOR MIG 907395
What is the correct gas for miller renegade 180 weder generator mig
    Problem Solver:
  • 17 Answers
Depends on the application and type of wire you are using. If you are using flux cored wire you want Co2. If you are using mig wire 75/25 blend (Argon/Co2) would be my choice. Your wire should also give you a recommendation of which type to use.
Posted on May 30, 2010
Spoolmate 100 wont feed
Check for binding int he inner sleeve first, then increase tension as long as feed motor spins. If feed motor does not spin check wiring to make sure it is connected correctly.
Sep 18, 2012 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Tig Welding settings for Renrgade 160VRD welder
Your machine is a MIG welder only. You can't do TIG. Sorry.
Dec 25, 2010 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Millermatic 180 wire don't feed lights won't come on fan keeps running
Machine will run only on 220V, check your braker nust be at lest 20Amp.
Dec 18, 2010 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Miller welder stsrts but shuts off new carb installed having problems with klinkage and carb adj/
Always look for the simple things like earth clamp, loose connections, coroded joints, bad solder joints , fuses, fuel filter, before you start pulling the set to bits,
Nov 18, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Spool wire starts to melt while on the spool
1] Switch off the mains power,remove the torch from the machine,ther should be a button or switch on the unit to feed the wire, push or switch these and observe that the wire feeds and dose not heat up, if ok then you have a short in the torch, a new torch assembly is required,if the wire heats up with the torch removed, the wire spool is shorting out, remove the spool and check wiring in and around the feed motor, if you can't see anything check for a voltage from a good earth and on the rollers, if you have a voltage then the motor is faulty.(earthing out) a P.A.T test should show exactly where this is.
Feb 16, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Mig proplem
Check the feed wheels at the wire spool make shure they are installed properly tight them if needed >>change tip >>
liner may need replaced.>
Dec 25, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Miller RENEGADE 180 WELDER GENERATOR MIG 907395 Logo
119 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
