Question about Craftsman 25cc Gas Line Trimmer
Starts fine but when I pull the trigger the engine stops.
  • cbollinger39 May 09, 2010
    Found the problem. Fuel filter was not connected to gas tubing in tank. Problem fixed. Thanks
  • 143 Answers
There are two screws on the side of the carburettor, H & L, if it is ticking over all right don`t touch the low (L) screw but slowly adjuse the high (H) screw in or out a wee bit until it runs. Stephen.
Posted on May 07, 2010
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
My waterblaster keeps stopping, it starts fine but when I go pull the trigger it will stop, after a while it will go for longer periods, then eventually it will keep going, it seems to me that not until...
It sounds like the air intake for the engine is clogged and its not getting enough air in the engine. See if you can find a tube with a foam textured top, this will be the air filter and you will need to clean it.
Aug 24, 2011 | Garden
When the trigger is off the motor stops and starts in quick succession until the trigger is pulled again
When the trigger is off your pump is overloading your engine this would be because the unloader is not doing its job try and change the pressure output of the pump this may unstick the unloader if not it may have to be taken apart.
Feb 04, 2011 | Karcher Garden
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
Pressure washer sputters and stalls when trigger is engaged
Hi k2times01
It is a always a good idea to clean out the gas tank and use new fuel, however, this sounds like an RPM problem. Try adjusting the RPM up a tad and see if it runs better when you load it. If the RPM isn't the problem, you may have to clean the carburetor thoroughly.
Jul 15, 2009 | Garden
Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Feb 16, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
242 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
