Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hot Water Heater Trouble
My hot water heater is not heating up the water. I have checked the breaker and don't have a clue as to what to do next. I also pushed the red reset button.
  • 2 more comments
  • cintheatalav Jul 29, 2008
    the water heaters is not heating up my water
  • nursel Aug 23, 2008
    No hot water. Breaker ck'd-it's OK Can't get in basement where water heater is located. Can't find keys.----what's next?
  • Anonymous Feb 14, 2009
    The green light on top is flashing. Pushing the reset button does not help.
  • parksd Feb 14, 2009
    The green light on top is flashing. Pushing the reset button does no good. I have also replaced the top element.
    Sniper:
  • 68 Answers
There are 2 checks for the heating elements:
#1 Check the voltage to element ( Black to ground, and red to either terminal of the element.
#2 Check resistance across the element. First turn the power off to the Water Heater, remove wires from element, then measure resistance across element. A good element could read anywhere from 9 K Ohms to 13 K Ohms depending on the voltage of the element. A bad resistance reading would be an infinite reading, or 0 Ohms.
If your elements check good, you might replace the thermastat
Please rate t
Posted on Jul 29, 2008
  • Jay Tate
    Jay Tate Jul 29, 2008
    Please rate this solution
    Problem Solver:
  • 8 Answers
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Posted on Mar 27, 2008
SOURCE:
No hot water.
1.reset circuit breakers on the home fusebox 2. reset the relays (the black boxes under the two covers) push in the red buttons 3. use a meter to check for resistance (ohms) on the elements 4. replace screw in electric heating elements
Feb 18, 2013 | Water Heaters
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Apr 17, 2011 | Whirlpool Water Heaters
I installed a new water heater it has power to it but it is net heating up, is there a reset button if I tripped a breaker within the unit
First a question. Did you fill the water heater until water ran freely at the hot taps.
If not you may have had an air pocket and blown an element. Water heaters will
always be shipped with the ECO in the reset position. The reset is a RED button
located under the upper cover for the thermostat. Shut off breaker to water heater
and remove this cover, and the fiber glass, then push the reset. Replace the fiberglas
and the cover securely and turn on power. You should actually hear the heater in most
cases. Remember that it takes about 45 minutes for a full tank of hot water from startup.
Feb 27, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
No heat the water.
Suddenly no hot water: Red reset button tripped, circuit breaker tripped, bad upper element, bad thermostat, loose wire, TP valve is running hot water out of tank, leaking faucet is running hot water out of tank.
1) Check for leaks.
2) Check circuit breaker.
3) Open top cover on water heater and push in red reset button.
If reset is popped out and will not reset, replace thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Test upper element:
5) Loose wire
Do full troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 01, 2011 | RELIANCE ELECTRIC WATER HEATER
Hi We have a GIANT waterheater 60gal 4500watt 94-12 Problem: The water heater doesn't heat up anymore since about 24hrs. It's not the breaker we checked that. AND if we would like to RESET with the...
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Dec 12, 2010 | Heating & Cooling
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
Nov 22, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Electric Water Heater not heating water
Most likely it is not your thermostats. First check your circuit breakers in your electrical box. It should be a double 30 amp breaker. PLEASE USE CAUTION WHEN WORKING A ELECTRICITY! Next above your upper thermostat you will see a red reset button, push it and it should reset. It will take a little time for your water heater to heat again. If you keep having this problem it may be your elements!
Jan 31, 2009 | Water Heaters
Residential electric hot water heater throwing br
If you reset the water heater the first time you were without, Then odds are it is the water heater. probably an element went back. If the power off check for continuity.
Please rate this response and Good Luck, Phil
Dec 28, 2008 | RELIANCE ELECTRIC WATER HEATER
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
379 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
