Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
Posted on May 07, 2010
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
What could be causing my 7 year old upright Frigidaire Model FFU21K2CW0 Freezer to NOT freeze? The inside (of the compartment) coils feel cold, the seal is good, but the ice cream is VERY soft. The...
Your freezer is probably running constantly as well. Lift the bottom vent panel (the one with all the holes in it) and look at the bottom of the back panel. There should be a half inch gap for the cold air return. If you see a solid wall of ice in that gap your coils have frozen over. You need to clean out the freezer and defrost it. Look in the back near the compressor. If your model does not have a drain plug in the bottom then you need to leave the door open and mop up the water as it melts off the coils from the inside. If you can, wheel it outside on a dolly and let it defrost where it can drain on its own. After you are sure it is totally defrosted, plug it back in at a control setting of 5 for at least 4 hours, preferrably overnight, and check the temp. Setting the freezer at 7 will encourage ice buildup. Your problem may be a bad defrost timer, which your local appliance parts store may have.
Aug 03, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Feb 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Continues to run
It seems your temp. control board or thermistor is not reading the temps and just keeps on running and running. Can you lower it to the lowest setting and (with a thermometer) see if the temps actually get warmer inside (will take a day or two to warm up). As for the ice on the bottom if the drain for the defrost cycle is plugged you may be getting water inside which then re-freezes. Let us know what you find and we can go from there.
Nov 26, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
214 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
