I HAVE A SAMSUNG DLP TV MODEL# HL-T5075S. TV GETS TURN ON BUT, AFTER ONE MINUTE SHUTS OFF AND ALL THREE LIGHT BLINK. LAMP,STANDBY,TIMER. I REPLACED WITH NEW LAMP,STILL DOING THE SAME THING. ARARIN
  • NURUL HASAN May 10, 2010
    I TRIED TO REALIGN THE LAMP AND ITS COVER TWO OR THREE TIMES BUT, STILL DOING THE SAME THING. TV COMES ON WITH SOME KIND OF STATIC AUDIO SOUND AND WITHIN 30 SECOND SHUTTS OFF. WHEN IT SHUTTS OF SCREEN GOES BLANK STATICK SOUND STAYS ON AND THREE LIGHT BLINKS. STAND BY LIGHT RED,TIMER LIGHT GREEN AND LAMP LIGHT GREEN. ALL THREE LIGHT BLINK SIMULTENEIOUSLY. PLEASE HELP ME. ARARIN.
  • 2,335 Answers
Review the alignment of the lamp & lamp cover.
There is a protective circuit that will not allow the TV to turn on if the lamp & its cover is not perfectly aligned.
I hope it is that simple for you.
Posted on May 07, 2010
I have a Samsung HLT5076S DLP Tv and when I turn it on I get a blinking Green Light for a couple of Mins. Then after awhile all three light start to blink. The standby light is Red and the timer and the...
It is the lamp but try to check the filament of the lamp if defective because if the color wheel is defective you will hear a whirring noise. Try to check the lamp if defective replace it and if you replace the lamp you should reset the lamp hour meter, feel free to send feed back good day and best regards.
Aug 22, 2011 | Samsung HL-T5076S 50 in. TV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
My samsung dlp hl-s5686w turns for a minute video disappears audio continues and three lights flash the standby/temp,timer,lamp. all at the same time.
I'm having the same problem. Tried several things from dusting the inside with an air blower, removing the bulb and putting it back in, making sure the side panel is installed correctly and none of this has kept it from shutting off. Samsung's site says the three lights flashing means replace the bulb but I'm not buying it. My picture looks perfect....jsut that the TV keeps turning off. It all seems like a heating problem but my fans are still working. I'm scratching my head thinking what to try before forking out $150 for a new bulb.
Apr 30, 2010 | Samsung HL-S5686W 56" HDTV
My samsung 5067w dlp tv does not turn on, the timer, lamp and temp/standby lights keep blinking. Please help!! Thanks
First check the color to see if its spinning or not. Replace it if neccessary. If that's ok, replace lamp and ballast.
Dec 23, 2009 | Samsung DLP HL-P5663W 56" TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
My DLP TV shut itself off & won't turn on, help!
The 3 lights on the tv are there to help you diagnose the problem. There should be Timer, Lamp, and Temp. If all 3 are blinking, the LED may be defective. If standby and temp are blinking, it's a problem w/the cooling fan.
Let me know if that helps.
Dec 15, 2008 | Microsoft Xbox 360 Console
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
