Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Fan running compressor not kicking on. canister feels really hot.
Canister feels really hot. no water in the tray under the fridge. cooling fan running compressor not.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Check that both wires to compressor are connected, trace them back to solinoid, , if the compressor isnot humming u only have 1 leg of power or it is bad
Posted on May 07, 2010
How frequently should the compressor run on a fridge?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The model number provided does not register. Your model number is located on the inside wall of your fresh food section.
Your freezer is your only source of cooling. It will meet its setting before meeting the refrigerator temperature.
The normal setting are -2 to +2 degrees F. for the freezer and 35 -40 degrees F. for your fresh food section.
Your freezer will go about 10 degrees F. above the set temperature. Then when it reaches 10 degrees F. below the set temperature the compressor will kick in.
You have condensing coils either under your unit or a canister in the back which gets ride of the heat. When the condensing coil is plugged up with dust, this could affect your cooling by as much as 40 degrees.
I do not think this is your total problem.
Feel the face of your separator wall between your freezer and fresh food section. Is it hot?
Your problem is your condenser fan in the lower right back of you unit is burned out.
So, you can not dissipate the heat.
Remove the lower back cover. Take a common household fan to blow air under your unit.
Your compressor is running to make up for the heat that the condenser fan can not dissipate.
Feb 27, 2015 | Electrolux Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Hot point Manufactured by GE MD# HSS25GFPE WW Not Cooling Fridge or Freezer.
Is compressor (black canister)running? It should be very warm if it is. If not, motherboard is most likely bad.
Oct 20, 2017 | Hotpoint HSS25GFP Side by Side...
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Kenmore 795.75212402 My ice maker drips water in ice tray and makes one big friggen ice cube. Removed inspection plate from back,cleaned everything(quite dusty) and noticed the cooling fan does not kick...
The fan you are talking only come on when the compressor is on. If the compressor is on and the fan is not. Feel the compressor to make sure it is not really hot. BE CAREFUL is can be extremely hot. If is you may have a big problem. The compressor could have whats called warped the internal composent do to heat. It is suppose to be warm to a little hot. If the compressor is not that hot and comp is on than replace fan.
As far as the ice maker drippind. The silinoid in the inlet valve may not be closing all the way. Replace inlet.
Jul 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
Frigidaire Refrigerator not cooling
Is the fan on the bottom on? Do you hear the compressor kick off and on within a minute? No/ Is the evaporator fan running? Do you have frost on the evaporator? Frost is a sign that the defrost isnt working. If evap fan doesnt run it wont cool the refrigerator. If everything is running and no frost buildup in freezer then you have a sealed system problem and need of a tech.
Jul 25, 2009 | Kenmore 50522 / 50524 Side by Side...
Fridge not cooling
Check the coolant pressure, you could have a leak. Sounds like everything else is working.
Jan 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
228 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
