Question about Neptune FB1602 Roma Elongated Front Toilet
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also makes a loud noise. I'm not sure if the toilet is the problem or or contractor installed it improperly....any thoughts?????
  • 10,865 Answers
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
Posted on May 07, 2010
Why does the toilet make so much noise filling FluidMaster 703A5B
Just replace the flush valve with another one.
Flush the water line by opening valve before attaching new flush valve
Aug 07, 2014 | Fluidmaster 507C White Flush Valve
50 year old American Standard toilet . Bowl fills up ,makes noises like it's pluged & then flushes
You have a blockage in the trap as the water goes out . What happens is that there is so much pressure with the water building up in the tank,, that it finally pushes the water out. Also check the vent above the toilet which is located on the roof. It must be free of debris to allow the pressure to stay equal and not a vacuum.
Feb 18, 2013 | American Standard Traditional Champion4...
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
My toto toilet flushes and refills fine, but it just started making loud noises when refilling. The noise stops when the tank is full
Your fill valve is going bad it can be replace with a new fluidmaster instead of the Ultra-G you have in it its going bad they do over time you may want to check your house water pressure in case that may have been what broke it you don';t want to break a new one.
Aug 29, 2011 | Toto MS853113S#11 UltraMax Round Toilet,...
I have neptune parma toilet, which was purchased 6 months ago. It was working fine but now it has a problem with filling up. It takes a minute before it will start filling up then it makes noise like...
This is usually the fill valve. Try adjusting the water height. If that doesn't work, you can replace the fill valve fairly inexpensively with a new one at any home improvement store
Aug 27, 2011 | Neptune FB1625 Parma Toilet
I have a Glacier Bay dual flush toilet that makes hissing noises sporadically. How do I make it stop?
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Jan 28, 2011 | Home
I just got a new Kohler toilet from HD. After installed it, it keeps running water fro every 10 minutes.
the water level could be adjusted too high and it is running down the overflow tube. if the fill valve makes a noise trying to fill every 10 minutes then you have a flapper on the flush mechanism that is not sealing properly. it may be out of shape or have something stuck under it.
Dec 29, 2010 | Kohler - Toilet - Two-piece - Highline -...
Noisy fill valve
You may have higher than normal water pressure. Try closing the the cutoff valve on the wall half way and see if that helps. You can experiment with it till you find the best position. You can get a pressure gauge that will attach to a hose bib for a few dollars to see if the pressure is too high (more than 80 psi is too high). If it is too high you can have a plumber install a pressure breaker on the line where it enters the house.
Apr 02, 2010 | Toto C743s-03 Drake Ound Toilet Bowl Only...
K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
Sep 13, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Neptune FB1602 Roma Elongated Front Toilet Logo
338 people viewed this question
Top Neptune Home Experts
JonSnell Electronic
JonSnell Electronic
Steve Waclo
Steve Waclo
Are you a Neptune Home Expert? Answer questions, earn points and help others
