Question about LG WM-2277HW Front Load Washer
LG front loader washer won't start
I am having a problem with my front loading LG washer. It does not want to start when I press on the button. It happened a few times over the past 6 months and after a few tries and days it will start. Is the switch worn out or is their a serious problem with the computer system? I have clothes in there now, and everytime I walk by the machine I press on the ON button and it doesn't start. I kinda want to go back to the basic machine!!!!
  • 1294 Answers
SOURCE: LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
Posted on May 29, 2007
  • 641 Answers
SOURCE: Mold Smell in front loading LG Tromm
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Posted on Aug 15, 2007
  • 489 Answers
SOURCE: Walking Washer
The best way to fix this problem is to adjust the front legs while the machine is spinning a full wash load.  Put in a load of clothes and run the machine to get the clothes nice and wet.  It will take about 5 minutes to get them completely wet.  Next, turn the washer off.  Now, turn the washer back on and push the spin button to select the extra fast speed.  You washer will go into a drain mode and then begin to toss the load into a balance spin mode.  Once the washer is spinning the clothes, check the balance of the unit by pushing the front left corner of the washer towards the right rear corner and right front corner towards the left rear corner.  If the sound of the washer quiets down on one side vs the other side, adjust the front leg to quiet that side.  Do not attempt to adjust the rear legs as they do not require adjustments at all.  Everything adjusts on the front legs.
This procedure works if the floor is sturdy enough.  If the floor is old and the wood is weak, it will not work.
Posted on Apr 27, 2008
  • 958 Answers
SOURCE: Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
SOURCE: Water leaking from my front load LG washer
If it's not the door gasket check the water control valves. They can continue to leak without the washer being turned on.
Posted on Jun 10, 2009
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
LG WM2277HB start button won't start cycle
Either the button is damaged or the switch it operates is malfunctioning.
Suggest you get a Technician to pop in and check it out while there is still plenty of life left in the machine!
Poppa
http://www.cdbaby.com/cd/poppamadison
Sep 23, 2012 | LG WM2277H Front Load Washer
Press the start/pause button on washer and it beeps at me. Won't let me start my load.
I would check that the front is secure. My old front end loader would kinda do the same thing. If I didnt have the door exactly shut it wouldn't start. Start there hope it helps
Dec 15, 2010 | GE Energy Star WCVH6260F Front Load Washer
How to i take the error code cl off my LG front loader
t means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it.
Apr 27, 2010 | LG WD-1280FHD Front Load Washer
Front door does not release
press the pause/ play button. This will unlock the door
Jul 11, 2009 | LG WM2688H Front Load Washer
Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Jul 04, 2008 | LG WD-1280FHD Front Load Washer
Front loader washing machine
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
363 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
