I tried to use webcam but no sounds. Could you help me how do I use the microphone with webcam??
    Problem Solver:
  • 5 Answers
Maybe you need a certain driver/software to use your microphone on your webcam.. what is the product name or model name and number of your webcam to be exact??
Posted on Mar 27, 2008
SOURCE:
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
I have my webcam set on the monitor about 60cm from me and I can't get the microphone to pick my voice
actually the the webcam microphone have some limitation to pick up the sound signal from that much distance. better use new seperate microphone . try it, It will work, thats all........... kpfrlewajveq0aaaaasuvork5cyii%3d
Feb 03, 2010 | Microsoft LifeCam VX-1000 Webcam
After installing my webcam, my microphone is not working on my laptop. I tried it on another machine and it worked fine. Is there a setting we are missing?
Yes, it is because GearHead WC330I WebCam has built-in microphone and apparently you also installed it's microphone.
What you can do now is to select which microphone to use and disable the other one.
Got to "Control Panel" Select "Sound" icon. From the "Sound Window" select "Recording" tab and disable one of your microphone which you don not want to use.
Hope this helps you. Thank you for using Fixya.
Jan 12, 2010 | Gear Head WC330I Webcam
No sound from microphone....
1)Go to Control Panel-> Sounds and Audio Devices.
Sounds and Audio Devices Properties window will get opened.
2)Click on 'Voice' tab.
3)In 'Voice Recording' group, Click 'Volume' Button.
4)Un check the 'Mute' check box under 'Microphone'.
Sep 09, 2009 | Creative Labs Video Blaster WebCam NX
Boynq Iris webcam microphone doesn't work
Try Skype - Preferences - Audio - Audio input and you should be able to select "boynq iris webcam".
Check out also the System Preferences - Sound - Input and you should also see "boynq iris webcam".
Mar 18, 2009 | Computers & Internet
Icannot get webcam microphone to work.how do i hook up microphone
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Mar 14, 2009 | Logitech Quickcam Chat Webcam
Mic problems
Go into the Control Panel and select Sound and Audio Devices.
Choose the tab Audio and then select under Sound Recording the Volume Button.
UNcheck any devices other than Microphone (checked). Also, put your microphone level midway.
See if that helps.
Nov 20, 2008 | Microsoft LifeCam VX-6000 Webcam
Mikomi Webcams
my mikomi has the same problem i have a picture but no microphone so im goin to take it back and get a normal webcam and a desktop microphone instead try this
Oct 19, 2008 | Computers & Internet
Microphone on my webcam
Aug 27, 2008 | Computers & Internet
WebCam VX-1000
Nov 25, 2007 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Ekse
 Grubhead
Grubhead
