Question about Refrigerators
Fridge not cold, compressor still runs, coils possibly frozen
  • Refrigerators Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
Refrigeratorfridge not cold, compressor still runs, coils - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 07, 2010
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Maytag side-by-side (MSD27 series) refridge is a superb unit, tremendous common-sense quality features -- BUT it just started running ALL the time, after major electrical storm. Freezer and fridge side...
Sounds like u need to clean the condenser coils behind the access panel in the back. When too much lint or dirt builds up it causes the unit to run inefficiently. If that doesn't improve things then it's possible that ur compressor is going bad and not working to it's fullest capabilities and it's about tk go bad. Maytag usually has an extended parts warranty on their compressor so check ur manual to see how long it's covered. A tech can do an amp draw on the compressor to verify if it's running to hard due to a bad winding.
Jul 06, 2011 | Maytag MSD2756G Side by Side Refrigerator
KITCHEN AID SIDE BY SIDE KSRP25FSMS01 We first niticed the freezer and fridge not being cold enough, then it stopped making ice. The freezer would not freeze things but still felt cold. I cleaned the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 18, 2010 | KitchenAid Refrigerators
Fridge coil is frozen but the fridge is not cold. Freezer coil is not frozen but freezer is cold. Icemaker doesn't produce ice and the water in the ice maker is not cold. What do you think?
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
234tghj
Jun 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Fridge and freezer not cooling properly. bottom s...
heatman101
68rjszndh
May 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
May 10, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
