Question about Rowenta Effective DX1900 Iron with Auto Shut-off
Iron shorted out, sparks and blew a circuit breaker in room
If i saw sparks and iron no longer turns on, can it be fixed?
  • 306 Answers
Depends on where the sparks came from. If it was from the cord then yes, fix the cord. If it came from inside the iron then, maybe. You would have to open iron and see what caused it. If you are and electrician or technician then you could measure resistance and find problem.
Posted on May 07, 2010
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
MY IRON POWER SON BUT DOES NOT HEAT UP THE LIGHTS JUST BLINK. WHAT IS WRONG WITH THIS IRON?
The thermostat is broken, the heating coil is short-circuited, or a fuse or other type of circuit breaker has otherwise opened.
If you are mechanically and electronically adept, then by all means try to identify the mechanical fault and fix it.
Otherwise, just replace it. Replacement parts for such a small appliance are not easy to find.
Mar 14, 2016 | Irons
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
I have a steamfast steamer that is tripping the circuit breaker. Any ideas why?
you check the wiring inside which may have short circuit, then the connector for filament which get short.
Nov 28, 2012 | Steam Fast SF-661 Iron
I have a Bosch b52l iron, when i turn on the steam button, it cuts off the power, what could it be
It could be the iron itself (it may have a short circuit in it) and the circuit breaker trips when the steam switch is turned on.
Option 1)
Another option is that the entire circuit that that circuit breaker is controlling is overloaded. What other outlets / applicances / lights are disabled when that circuit breaker trips? You may have to iron only when those other applicances on that circuit are not being used.
Option 2a) Your outlet may be damaged and causing your circuit breaker to trip when the high current STEAM setting is set.
- OR -
Option 2b) the circuit breaker is damaged and is tripping too easily. Only replace with a similarly sized circuit breaker (15 amp lis likely but is says right on the breaker).
Try the solutions in that order.
-Mark
Please rate me..
May 07, 2011 | Bosch Irons
Trips circuit breaker after 10 minutes of use
This iron is 1500 watts. On a 120 volt breaker, that's about 12.5 amps. Check to see what else is on this breaker. A 1500 watt space heater or a washing machine combined with this iron will pop a 15 or 20 amp breaker.
Mar 03, 2011 | Rowenta Professional DX8800 Iron
I have a 1750 watt Rowenta Professional iron. The cord end accidentally fell into a vat of saltwater that was under the shelf where I store my iron. (The saltwater is for my marine fish tank). Now the...
The residual salt inside will be enough for the GFI to think that there is a short in the iron...
Shoet of takeing the iron completely apart and cleaning everything there is nothing you can do...
heatman101
Aug 23, 2010 | Rowenta Irons
I replaced the badly worn cord on a Phillips steam iron and everytime I switch it on it throws the circuit breaker. I am assured that the iron was working OK before I replaced the cord, but because it is a...
There is a break in the insulation somewhere and tge wires are getting crossed or the active wire insulation is broken and it is shorting to the eaarth ground.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 23, 2010 | Micro Pro 7599 Iron
Steam iron trips the main fuse
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Sep 07, 2009 | Philips HI-296 Iron
Shark steam iron
I always purchase your Product and Irons. I like your product very much. so please provide me with address to sent this Iron back for repair. It has always made the lights in the room whenever I Iron go on and off. Also shuts off and on during ironing, then and water leaks from the iron. " Please Help"
Martin
Oct 16, 2008 | Euro-Pro Shark GI490 Iron
Rowenta Effective DX1900 Iron with Auto Shut-off Logo
310 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
