Question about GE Dryers
My GE Profile dryer is wedging clothes in the front of the drum and seemingly 'scorching' them. I can move the drum up and down by grabbing the paddles on the inside. What could be causing it and how would I repair it?
  • 20 Answers
Check the tumbler hinge on the back of the tumblermake sure its not worn out
Posted on May 08, 2010
Gas dryer yellow stains
Check inside your drum for a crayon stuck to it
Dec 04, 2017 | GE Profile DPSB620GCWW Gas Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
I am having a problem with my Ge dryer catching my clothes somewhere in the front by the top of the door it rips the clothes when trying to get them free can you help
it may be snagging clothes on a sharp edge or flashing on the plastic light assembly overhead of the door. you might just need to take a small piece of fine sandpaper and remove the burr or sharp edge thats snagging stuff..
also one or both of the rollers in the front may be worn, allowing the drum to bear down on the seal more, opening a gap at the bottom to grab your clothes then pulling them around with it, you just happen to catch it when its stopped and sitting still just hanging there.. while u have it apart u might as well check the rest of the rotating parts out for wear, etc and replace while you have it opened up..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How do i get new belt on ge profile dryer ?
This is actually not that complicated. Unplug the machine. Lie it on its back. Remove all screws holding the front panel on. Disconnect the doorswitch wires don't worry you can cross them either way when replacing them. Remove the front panel. If you look down to your right side bottom corner you'll see the drive motor and tensioner spring. Remove the old belt. Slide the new belt over the drum, making sure the correct side is in contact with the drum, you usually can tell by looking at the old belt.
When it comes to the drive motor and tensioner(use care not to let the tensioner fall out, it only sits in a slot on the bottom panel. After you have the belt in its groove around the drum, worm it over the drive gear and pull the tensioner back enough to grab the belt.
Aug 21, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Snagged Clothing on drum of dryer
why does the dryer make a rubbing sound it drys the clothes is it clogged maybe
with lint on the bottom of the dryer please give me answer to this question .
Thank you
Linda maldonado
May 27, 2009 | Kenmore 63942 Dryer
GE DSXH436V1WW heavy duty large cloths get caught
This dryer doesn't have rollers at the front of the drum, it uses a felt rub strip between the drum and the front cover. You'll need to replace the rub strip. It's easy to do but you'll need to get the special high-temp adhesive.
Feb 24, 2009 | Dryers
GE Profile Dryer will Not Spin
I opened the dryer panel and saw that one of the two belts that stabilize the drum had come off. It is a soft, sticky, rubbery substance and part of it and balled up so it was wedged between the drum and the dryer wall. I cut that portion off and it runs fine now.
Dec 07, 2008 | GE Profile Harmony DPGT750EC Electric...
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
May 31, 2008 | Dryers
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Dec 19, 2007 | Dryers
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
