Question about Leica 40342 Trinovid Compact Binoculars Black Armored w/ Case
How do i fix the loose hinge on my Leica Trinovid binoculars?
  • idahoflyfish May 07, 2010
    It seems like there ought to be a way to access the hinge at home and and work on it . . .
  • 12,061 Answers
Wekk what i have done before is to use some light adhesive, and inject irt into the Hinge area, now work the hinge backwards and forwards as the glue drys, to ensure that it will NOT glue it solid, keep moving the hinge until the setting period, has expired, now you will find, that the increased resistance offered by the "Glue" remnants, is often enough to take the Slack out of the Hinge. Sometimes too a Silicone sealant can be injected into the space, and again worked in, this too, often increases resistance enough, to give more friction, or sticktion, and allow for a "Tighter" feeling hinge. Another way i have used is to use a soldering iron, and dimple the bottom surface of the hinge, with the effect of having a little pattern of Pin-Hills, that again, will "Bind" up the hinge somewhat and again, tighten it all up. another methods have used a small screw just binding through the bottom of the hinge, and just enough to impinge of the bearing inside, and again, stiffen it all up.
Posted on May 07, 2010
  • 10,865 Answers
Hello. Go to this link to find the Leica service center nearest to you.
http://kartendienst.falk.de/index.jsp?CID=81&SET=locator&LANG=GBR&STYLE=usa
Start out with an estimate and then you can decide if you want to let them do a factory repair. Joe
Do the eyepieces adjust for pupil width, as in side to side? thanks
Yes, just like on all but the very cheapest of binoculars.
Assuming that you are asking about the Leica Geovid BD 7x42, there's an obvious central hinge down the middle of the unit and you just straighten the hinge to increase the inter-ocular distance and bend at the hinge to reduce it. Exactly the same as on almost all binoculars.
Mar 03, 2010 | Leica Geovid BD (7x42) Binocular
The strap fixing on one side has come adrift from the body of the binoculars
This needs to be returned to leica for repair. That lug is integral with the body and that is the only solution. The place that you bought them from should be able to give you further information on the return for warranty repair.
Feb 28, 2010 | Zhumell Leica Ultravid 8x50 Rubber Armored...
I have the old 8x40 leica binos. the pivot hings
Send them to me, and I'll fix that for $50.
James 718-578-5231
Jan 10, 2010 | Leica Optics
Leitz Trinovid 7X35 needs new rubber eyepieces
have had nothing but excellent results when ordering eytops for leitz that i repair.. call..1 800 222 0118....x217..gl larry@reichinstruments.com
Jun 08, 2009 | Zeiss Classic B/GA 524013 Binocular
Hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
Feb 19, 2009 | Nikon Sporter I Binoculars
LEITZ TRINOVID 10X22C BINOCULARS
Yes , but note that covers are glued so use a pin to  lift cover gently . The screw should be secured --when you are finished tightening-- with 'locktight' or touch of nail varnish.
Oct 28, 2007 | Carson Optical Tracker 8 x 21 mm Ruby Wide...
Leitz trinovid binoculars
I am trying to get Leitz binoculars repaired. Do you know where I can send them?
Ash
Oct 15, 2007 | Zeiss Classic B/GA 524013 Binocular
Leica 40342 Trinovid Compact Binoculars Black Armored w/ Case Logo
71 people viewed this question
Top Leica Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Bill Boyd
Are you a Leica Optic Expert? Answer questions, earn points and help others
