Question about Panasonic PT-52LCX66 Projection Television
TY-LA1001-K I replaced the lamp and didnt restet
TY-LA1001-K I replaced the lamp and didnt restet the lamp timer, there were no instructions on how to. The tv was fine for a week, and still works fine but gives a message that the bulb needs replaced and the lamp timer needs to be reset. the red light indicator is on I think the lamp timer is the problem how do I reset it.
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
Posted on Sep 05, 2010
  • suefultz Jan 13, 2011
    If your remote does not have PIP or Split buttons, you need to hold the volume down button and press 0 on the remote holding the two at least 5 seconds. I was able to reset mine that way.
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
Tip
Panasonic TY-LA1001 Lamp Replacement Manual
The Panasonic TY-LA1001 is one of the rarest enclosures in the entire DLP market to find. The same applies to the manual, so we are very proud to offer all of our visitors the replacement manual for the TY-LA1001, enjoy.
here is the link so you can download the PDF
http://www.fixyourdlp.com/2010/01/11/panasonic-ty-la1001-lamp-replacement-manual/
on Mar 24, 2010 | Televison & Video
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
How to remove yellow in center of screen on panasonic pt-52lcx66-k hdtv
You might start by cleaning the lenses & mirror(this may use a Mylar sheet rather than mirror,don't try to clean the mylar) then install a new lamp
part#: TY-LA1001 $70.00 http://www.tvpartsguy.com/servlet/the-11855/TV-Lamp-TY-dsh-LA1001-for/Detail
or $49.00 to $80.00 http://www.shopjimmy.com/catalogsearch/result/?q=ty-la1001
If that doesn't cure it you most likely need a new light engine/optic block which would make the repairs cost prohibitive even if you can locate the light engine.
May 15, 2014 | Televison & Video
How to remove yellow color in center of tv screen on pt-52lcx66-k panasonic hdtv
May 15, 2014 | Panasonic PT-47WX53 47" Rear Projection...
Reset lamp meter on panasonic pt 56lcx 16
Turn on the projector MENU- OPTION- LAMP RUNTIME- Press and hold the ENTER button for 3 seconds. Turn off the power.
Dec 07, 2013 | Panasonic 2 Projector Lamp
I need to reset the lamp on a 52in panasonic HDTV with a TY-LA1001 lamp.
Reset procedure comes along with TY-LA1001 lamp, please check lamp packing for instructions or click HERE to download it.
Thanks.
May 04, 2011 | Audio Players & Recorders
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
PT-52LCX66-K picture is darker than normal...
Sounds like you need to replace your lamp. The lamp number for this panasonic TV is TY-LA1001. Lamps run anywhere from $120-$250.
Nov 12, 2008 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-52LCX66 Projection Television Logo
1,435 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
