Question about Saeco Magic De Luxe Espresso Machine
Opened the grounds cup while machine powering on, now it's blocked
I opened the grounds cup to empty it while my Saeco Magic De Luxe Espresso machine was powering up. Now something is blocking it from completely being inserted. Assistance would be greatly appreciated.
    Scholar:
  • 70 Answers
Here's the deal.
1. As you've probably learned by now, don't take anything from teh machine when its powering up and even when its going threw a brew cycle.
Here's whats happened, There's a set of microswitches that connect to the main board on the unit. One of the switches is triggered by the grounds cup.
When one of the switches is set off the unit goes into alarm and locks down.
Now to your problem. When the machine starts up its just like a brew cycle. The machine goes threw a Test mode of sorts where its checking the brew drive.
Once you pulled the ground cup, i'm almost 100% positive (its a common problem) that you set the alarm off mid cycle and jammed the brew group in place.
Since the brew group switch and the ground cup switch are so close together, it basically jams them both per say.
So basically unjam the brew drive to its original position is the only way to fix the problem.
Option 1: 2 tiny screw drivers. Turn the machine on. By the brew drive there's should be 2 holes where there's little metal clips stick out. When you press them with the screw drivers, the machine will trigger the brew drive back to the original settings.
Option 2: Flat head screw driver. where the grounds cup is there should be a little slice on the machine. turn machine on. place screwdriver there, brew drive should go threw test and then back to original position. Once everything stops, you should be good to go.
Option 3: Sent out for service. Worst case scenario.
Don't use alot of pressure as these pieces are all aluminum and plastic.
Wish ya the best of luck.
Posted on May 25, 2008
SOURCE:
Saeco Intuita adjust water volume
Press and hold the coffee button the entire time until the cup gets to the length that you prefer, then let go. That will program the cup to that length.
Saeco Parts
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Sep 14, 2013 | Saeco Magic De Luxe Espresso Machine
How does a Saeco Magic De Luxe Espress machine know the dregs drawer needs the be emptied and turns on the light? Does is just count the pucks that are put into the drawer or is there some type of sensor?
Simple answer is it counts how many coffees have been made. If you turn the machine off and then empty the dredge drawer the machine doesn't know this. and the light will remain on. Leaving the machine on when you empty the drawer lets the machine know that you emptied it (15 seconds out) and it will turn the light off.
Oct 07, 2010 | Saeco Magic De Luxe Espresso Machine
I have a Saeco Magic De Luxe. I am having a problem intermittent
Could be the pump not providing enough pressure to force the water through the coffee. When using beans or preground, can you still hear the pump function?
Jun 30, 2009 | Saeco Magic De Luxe Espresso Machine
Tip is broken - Saeco Magic Deluxe Expresso, Coffee Maker
In the UK Saeco parts are supplied by Gaggia UK in Halifax
Dec 13, 2008 | Saeco Magic De Luxe Espresso Machine
Looking for user's manual for Saeco Stratos Expresso Machine
There are a user manual on this site under Saeco/magic de luxe espresso machine.
Aug 09, 2008 | Saeco Magic De Luxe Espresso Machine
Cup warming pad
I think, if the machine goes in standby then the warming pad also goes in standby.
/Mirran
Aug 06, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
128 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
