Question about Craftsman Garden
I have a Craftsman YT4000 which is leaking oil from the fuel pump? What is my problem?
I have the same mower, 18.5hp and mine is leaking oil from the fuel pump. I replaced the fuel pump and the same issue. Sears came out and could not duplicate the problem. Changed all the oil, plug, filter(s), etc and ran for about 2 weeks...now it is doing it again. At $100 a whack, Sears is making a killing on saying I don't know.
Posted on May 28, 2010
Owner's manual for craftsman YT4000 model 917.288561
Bob, Check the attached links, Craftsman Riding Mowers instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/yt_4000.html
Craftsman 28925 YT 4000 24 HP 42 Yard Tractor Manual
Apr 05, 2016 | Craftsman Garden
Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Jun 22, 2015 | Craftsman Garden
I HAVE A CRAFTSMAN GARDEN TRACTOR WITH A KHOLER ENGINE MODEL CV730-0029. WHEN THE ENGINE IS RUNNING IT SMOKES QUITE A LOT. I CHANGE THE SPARK PLUGS, FUEL FILTER, AIR FILTER, OIL FILTER AND OIL AND I
First you need resolve the carburetor issue. With it leaking fuel it can flooding the engine causing it to smoke. The leaking can dilute the engine oil by overfilling the crankcase causing smoking and other damage, Once carburetor issue is resolve and it still smokes the initial 10 minute start-up after the rebuild then a compression and leak down will need to done to determine if you have blown head gasket, bad rings, or other problems.
Oct 14, 2014 | Garden
Why won't my Craftsman YT4000 tractor start after removing the deck?
Deck Height switch isn't engaged or pushed in when you remove the deck and it will not start. No current can flow until this switch is pushed in.
Jul 26, 2014 | Craftsman Garden
How do I get my Craftsman YT4000 to catch grass into the bag again?
do you have bagging blades in place? reg blades will not lift enogh
May 23, 2012 | Garden
Oil leaking out of fuel pump after putting a new fuel pump on.
is the engine over fulled with oil? are you getting gas in the oil over filling it? if so check the needle valve in the carb
Apr 11, 2012 | Craftsman Garden
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Oil leaked out
Most utility pumps use mineral oil, but more importantly how did it run out? If a seal was bad the oil should have been milky. It will overheat without proper oil level.
Feb 21, 2009 | Craftsman Professional 1/4 Hp Submersible...
Garden Logo
202 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
