Question about Dell Dimension 3000 PC Desktop
Extremely slow boot it is slow opening windows slow doing everything it takes like 30 min or better just to get into windows xp
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Please open your command prompt and type "defrag c: -b"
Start > Run > Cmd > defrag c: -b
Also check the services running in background
Start > Run > services.msc
Set your web servers and other antivirus programs to manual.
You can also use some reliable tool such as reginout to fixup registry related issues.
Hope it would help you.
Posted on Jul 01, 2011
  • 4 Answers
David_rplry8: i think the problem you face is due to less memory in ur pc or i could give u some more hints if u could b abit more detail in explaining ur problem.
Apart from that i can simply make out from the bits of explaination that u jst did, is that you r running low in memory and you definitely need to upgrade if u r interested in making ur PC work fast.
Posted on May 07, 2010
How to install windows xp to a toshiba dynabook SS 2000m. . . . . ?
First you must have a windows xp install disk. Insert it into the cd drive and boot from it. Follow the on screen instructions. It may take anywhere from an 30 mins to an hour
Mar 01, 2011 | Toshiba Computers & Internet
Start up is so slow.what should i do?
There is a lot you can do ... I assume it used to run fairly well? This place is good advice..
http://www.wikihow.com/Make-Windows-XP-Startup-Faster
This is deeper and good too..
http://www.microsoft.com/windowsxp/using/setup/expert/northrup_restoreperf.mspx
Here is a lot of different post by different people. These you need to know a little about to act on..
http://www.softwaretipsandtricks.com/forum/windows-xp/5264-extremely-slow-boot-up-windows-xp.html
Feb 06, 2011 | Computers & Internet
I had problems with an extremely slow pc. I replaced mcafee with Norton 360. Norton found a few trojans,etc. All removed and i undertook a disk defragment. Then Windows xp home edition did not start in...
Both Norton and Mcafee are known for slowing pc's down.
Boot your PC as normal, but as its starting keep pressing the F8 key until some options appear on your screen. On of which will be "boot windows in safe mode".
Select that option and a windows shell should open.
Once open got to Start - Control Panel - Add/remove programmes and uninstal both mcafee and norton.
Once complete, reboot and see how you PC runs.
Assuming its working ok now, go back to your control panel - security centre - enable windows firewall.
Go online to "Filehippo.com" and download and istall the free version of AVG (anti virus software) once installed let it scan your system.
Then go back to Filehippo.com, download and install Ccleaner. This has loads of tools, :-
1) Cleaner clears all the tempory internet files of your pc.
2) Startup - you can reduce the number of programes you want th start up when booting.
You don't need any here because you can access all programmes via start but I'd leave AVG and any securtiy related to start and delete the rest. But its probably better to just disable the rest until you're happy with which programmes auto start.
Good Luck
May 08, 2010 | Microsoft Windows XP Home Edition
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
E-machine t5048 very slow
the ticking noise sounds like you need a new hard drive, if your on wireless connected internet it will run slow depending on the strength of your connection
Mar 29, 2009 | E-Machines eMachines Desktop PC
Very very very slow performance
That is way off buddy should take no more than 1 hour to install and you should be able to boot up into windows in 30 seconds or less. I suggest you first run a virus checker. You probably have a virus that is why it is taking so long. If their are too many virus;s then wipe all the data off your hard drive and reinstall. That will get rid of the virus. Also run disk cleanup and disk defrag that are in the accessories/system tools. Good luck, let me know if you have any questions.
Mar 29, 2009 | Dell OptiPlex GX260 PC Desktop
Exactly same slow working especially slow boot up and shut down problem with Cpmpaq EVO N610c.I reformatted twice and installed windows xp professional but still same proble.i have 30 gb hard disk with...
Hi there
Don't bother with service pack 3, it will only slow the pc down even more, what you need is a memory upgrade so the machine can perform well, also a better hard drive would be a good idea
kind regards and please don't forget to rate us
Dec 09, 2008 | Microsoft Windows XP Professional With...
Dell Latitude won't boot up and reinstalling Windows XP is taking forever
well it could be a bad sector on the hardrive .. couple of questions did you reformat the drive you are installing it in? Did it give you that option on your reinstall?
Sep 21, 2008 | Dell Latitude D600 Notebook
Windows XP Unusually Slow Startup
from msconfig you disable all startup item and restart.Also you defragment your hard drive once in a month and use a good antiviruse and scan your pc at regular interval
Jun 23, 2008 | Microsoft Windows XP Professional
plz go to msconfig and disable all item except the antiviruse in the startup tab, then go to my computer propeties ,click on advance then click on performance then select adjust for best performance(visual tab) then go to advance tab and change the page file to 1024 for both(min and max) then do a full scale system scan for viruse
Post your findings
Apr 28, 2008 | Microsoft Windows XP Media Center Edition...
Dell Dimension 3000 PC Desktop Logo
85 people viewed this question
Alun Cox
