Question about Frigidaire GLEQ2152ES Electric Dryer
DRUM TURNS BUT NO HEAT EVERY THING ELSE WORKS FINE JUST NO HEAT DRYER JUST 2YR OLD
  • 306 Answers
The heating circuit has a few compontents allowing ignition. One is a high temp fuse that once it blows you need a new one. This can be caused from lack of cleaning the lint filter. Since your dryer is not very old this would be a very probable cause.
Posted on May 07, 2010
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
New Dryer, drum turns but no heat.
Check your breaker. Reset it.
Apr 22, 2009 | Dryers
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Scraping sound when tub is rotating.
The motor turning the drum may be bad OR the spindle or axle the drum turns on may be bad as well. The belt turning the drum may have been to tight thus putting too much pressure on the drum which eventually would wear it out then causing the noise which will only get louder as time goes on.
You will need to take off the back of the dryer and possibly the top to gain proper access to the drum and motor.
Jan 14, 2009 | Dryers
Our 2-year old Frigidair dryer, Model # GLER341A was working fine-I removed the dry clothes, put in the next load, turned it on and it sounded like a load of chains was in it.. When I opened the door...
could be rear drum bearing. possible heat element broke and is rubbing on back of drum those light you say you saw was probably your heat element arcking on the metal in other words sparking
Jan 12, 2009 | Frigidaire GLER341A Electric Dryer
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
100 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
