Question about John Deere Tractor 50, 60, 70, ITJD10
What is the correct method to install water pump
What is the correct method to install a water pump on John Deere Model 70 Tractor? I have used new gaskets, attempted to install twice and still have leaks. both on the block & water pump connection to the radiator.
  • 3,740 Answers
Buy some Gasket Maker
See this link:
http://www.permatex.com/documents/GasketMakerSelector.pdf
The sealant your going to use is blue and is Item # 81724
If it leaks after using this then you may have a cracked water pump housing in the block.
Just follow the directions on the package. There is usually a wait time before installation.
Permatex® Ultra
Blue® RTV Silicone
Gasket Maker
Item # 81724
Valve covers, oil
pans, differential
housings, intake
manifold end seals,
timing covers,
thermostat housings.
Temperature Range:
-65°F to 500°F
intermittent
There is one other sealant you can use
Permatex®
Water Pump &
Thermostat RTV
Silicone Gasket
Item # 22071
Water pump, thermostat
housings.
Temperature Range:
-65°F to 650°F
intermittent
If your housing is cracked JB Weld has a broduct called water weld that works great!
http://jbweld.net/products/water.php
Thanks for using FixYa.
Kelly
Posted on May 07, 2010
  • 10,865 Answers
Hello. Make sure the metal surfaces are all perfectly clean and sanded smooth with emery cloth. make sure the gaskets fit well. if not trim them. Finally if all else fails use some gasket cement to insure a leak proof water pump. This gasket cement is a common item available at most hardware and auto parts stores. Joe
I have a john Deere 445 garden tractor with a coolant leak up by water pump. Would this just be a gasket or does it have a weap hole
Check hoses before you tear anything apart. The water pump could be bad as I don't think there should be any moisture around anything. Bad hose will leak some times where they fasten on the pump or could just need to be tightened.
Good luck.
Apr 15, 2015 | John Deere Garden
No fluid from rear pump 410 john deere backhoe
1st ck hyd tank for fluid level and fluid quality 2nd remove and ck hyd filter for blockage (note some hyd filters have a water sensing block valve inside) 3 rd verify that fluid is reaching pump , pumps will make horrible noises with no fluid in them , if all are well replace pump , and ck that bypass valve is not stuck open and is set correctly (some are internal to pump )
a method i've been sucessful with is to temp power hyd system with remote from another working tractor/bobcat , this sometimes unsticks bypass valves , but unless your familiar with what fittings do what and such I don't recomend this action for novices
Mar 19, 2014 | John Deere Garden
My 1995 6200 John Deere is running hotter than normal. Done coolant flush. Blown out aircleaner, washed out radiator fins. Whats next?
IF YOU ARE NOT HAVING WATER BLOWING OUT WHEN YOU START IT IT PROBLEY NOT HEAD GASKET I WOULD LOOK AT WATER PUMP THE IMPALER COULD BE BAD IN THE WATER PUMP
Nov 10, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
Can u tell me what size of hydrolic pump is fitted to 1850 john deere tractor
There are 3 pumps that were used on this model.
Part number is:
AR103035
alternate / sub PN: AL70641
This 8 piston 11.3 CM3 pump is rebuildable at a fraction of the cost of a new or re-manufactured pump.
http://cheaptractorparts.com/store/product5697.html
There are 6 kits for this pump depending on what has failed on the pump.
Kits
AL71015
AL71016
AL71017
AL71018
AL71019
AL71020
The John Deere Parts catalog can be found here using you model number:
http://jdpc.deere.com
Pump PN: AR103036 23CM3=1.4 CU.IN
and
Pump PN: AR97872 40CM3=2.4 CU.IN
All of these pumps can be repaired. It just takes a talented and patient person to do the repairs with kit parts in hand.
Thanks for choosing Fixya,
Kelly
May 01, 2011 | John Deere 5420 Tractor
How do I fix a broken steele line on a John Deere 425 lawn tractor which operates the power steering and hydraulic valve body?
The easiest way is to go to a John Deere dealer with the model and serial number and old part if you have it off and buy the correct replacement part that is all bent and flafed to fit eactly where it belongs the other idea is to take the failed lint to you local auot parts store and buy a piece of steel tube of the right diameter with the correct ends, and take it home and bend it to match the failed part and reinstall it, being sure to bleed the air out of the system when you have everything re-installed. Hope this Helps Don
Nov 08, 2009 | John Deere Steel Chain/farm/tractor/john...
I NEED INJECTOR PUMP SCHEMATIC FOR JD 400 PUMP
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Apr 18, 2009 | Garden
Ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Feb 20, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
John Deere Tractor 50, 60, 70, ITJD10 Logo
384 people viewed this question
Top John Deere Toys Experts
Jim Goldsmith
Jim Goldsmith
J.D. Browning
J.D. Browning
Wayne Fellows
Wayne Fellows
Are you a John Deere Toy Expert? Answer questions, earn points and help others
