Question about General Electric APE08AK Portable Air Conditioner
I need a condenser motor for this unit,Portable GE AC M/N APEO8AKM1
I,m looking where i can go to get the manual for the GE 8000BTU portable air conditioner model # APE08AJ please help
Posted on Jul 27, 2011
  • General Elec... Master
  • 43,501 Answers
P2 code is on Alen AC portable unit. Have emptied tank, unplugged, reset and still have P2 code on.
I am not completely familiar with these units but I believe they use a float to determine condensate levels. This float may be stuck in the raised position.
Sep 13, 2014 | Alen C360 Portable Air Conditioner
Sharp portable air conditioner
If the unit wont cool then its more cost effective to replace the unit. Mostly it'll cost as much or a little less than a new unit for repairs
Aug 05, 2013 | Heating & Cooling
When i run the ac it leaks on the floor from the inside n i dont know what to do about this problem.
All portable or window ac units are mounted or standing with the back lower housing at a slope
so that the condensed water buildup from the evaporator can drain into a tray or thru a tube out
the back of the unit, depending on what kind of unit you have you may have to take it apart and
make sure the drain for the condensed water is not blocked. some times these units are not
installed correctly, they will not drain properly and standing water with time will turn to rust and
clog up the tube where it needs to flow from the ac unit. good luck!
Jul 31, 2011 | Windchaser PACR10000 Portable Air...
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
Ge ape08akm1 portable ac unit
the port out the back has to be pushed down so it angles down. If its level it will drain into the tank
Jul 27, 2009 | GE APN08AA Portable Air Conditioner
Whirlpool portable AC, compressor works, but no exhaust fan
there are 3 possiblities
  1. something obstructing the lower fan motor (or exhaust motor)
  2. bad fan capacitor
  3. or bad motor
to check any of these you will need to disassemble the unit to get to the blower. there are several screws located at various points on the plastic housing covering the unit. Once removed you should be able to check for motor obstructions visually. for checking the motor and capacitor you will need a volt/ohm meter and ideally a capacitor checker. you could try to spin start the motor while it is powered up this could be a possible sign of a bad capacitor if it will start when you do this or if the motor will spin freely while powered down and will not spin start when powered up. I know that is kind of confusing but its how they work. GO FIGURE.  thanks Peyton
Mar 15, 2009 | Whirlpool ACP102PS Portable Air...
General Electric APE08AK Portable Air Conditioner Logo
347 people viewed this question
Top General Electric Heating & Cooling Experts
Donni Steen
Bill Long
AJMAL KHAN
Are you a General Electric Heating and Cooling Expert? Answer questions, earn points and help others
