Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome 10001 - bobbin winding starts okay but it
Janome 10001 - bobbin winding starts okay but it stops after a few rounds. While in operation the machine feet keeps working as if in the sewing mode. How to fix it
  • Janome Master
  • 1,388 Answers
Bobbin winder sensor needs repair or replacing
Posted on Nov 28, 2011
    Genius:
  • 1,116 Answers
Take it to a Janome dealer for repair.
Posted on May 07, 2010
Re Janome 7330 bobbin winding problem. Thread jumps out of the top guide when bobbin is winding. I've tried everything; different speeds, main spool upright,tightening the screw on the thread guide.
Take a look at this video. There are others too. That is a really unusual way and nothing like the Singers, and Pinnocks that I have used. If you want to see other videos, there are a few. Google 'Janome 7330 bobbin winding', and then click on the Video tab. Let me know how you get on?
How to Wind Bobbin on Janome
Dec 04, 2015 | Janome Sewing Machines
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
Bobbin winding stops after few minutes of winding, & will start again but does same thing
I don't have your machine but this sometimes happens to me when the tread piles up at the top or bottom of the bobbin. If that is the case with your machine then try to guide the thread so it winds on evenly.
Jun 24, 2015 | Janome Memory Craft 10000
Janome 6600 bobbin will not wind error "stop for safety purposes"
I have a feeling the sensor has been jolted just enough to make it stop. Pretty sure this can be adjusted by the dealer quickly. Worse case scenario, you'll have to replace a sensor.
Feb 25, 2015 | Janome Sewing Machines
Janome sew mini will not fill the bobbin
a part of the bobbin winder is not working and should be checked
Mar 25, 2014 | Janome SEW MINI Mechanical Sewing Machine
Bobbin winder not spinning
I think you have to flip a switch , watch the screen for instructions and then step on the foot control.
Jan 22, 2014 | Janome Sewing Machines
I pulled out the lubricating strip under the bobbin
Bobbin Winding 1 Put spool of thread on spool pin. ] Use spool cushion when using cross wound thread. ] Use spool cap when using parallelwound thread. 2 Lift thread guide bar all the way up, and run thread through triangular thread guide as shown in drawing. 3Run thread through bobbin winding thread guide as shown in drawing. 4 Run thread through top thread notch 1, and align bottom thread notch 2 with guide pin on bobbin winder shaft. 5 Press bobbin stop up against empty bobbin. If the bobbin stop does not slide easily between the top and bottom of the bobbin, check that the bobbin is seated properly with the guide pin (4) inserted into the lower notch 6 While holding the end of the thread, step on the foot controller for a few seconds. Once enough thread has wound itself around the bobbin to hold itself in place, release the foot controller and trim the excess thread. 7 Stop winding when bobbin Begin
8 Manually move bobbin stop back to original position. 9 Cut thread and remove bobbin.
bobbin insertion 1 Lift slide plate (and open bobbin door). 2 Put bobbin into the bobbin case. ] Run thread through thread notch and under latch spring, so that a length of about 10 cm is exposed. ] Use a bobbin case with an idling prevention spring. 3 Pull the latch lever of the bobbin case out and push the bobbin case into the shuttle race and release the latch lever. ] If the latch lever is not all the way on the hook, it may fly off during sewing and cause lower thread breakage. 4 Lower slide plate and close bobbin door, following numbers 1 2 above in order. 6 While holding the end of the thread, step on the foot controller for a few seconds. Once enough thread has wound itself around the bobbin to hold itself in place, release the foot controller and trim the excess thread. 7 Stop winding when bobbin is full. Take foot off foot controller. * Place the thread end so that it does not protrude from the bobbin. Bobbin Stop
so this will be ok and no need to worry about this
Jun 23, 2009 | Singer CE-200 Quantum Futura Computerized...
Janome Memory Craft 10001
Are you checking the simple things such as making sure you have the presser foot up when you thread and the tensions set between 4 and 6, bobbin in the correct way round and tension enough to pull the thread through with some resistence.
Jan 02, 2009 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
476 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
