Question about Dishwashers
I am getting a default code of "HO" after the dishwasher runs for about 20 mins. The dishwasher is a Fridge Model FDB2310LCC2 What is the "HO" default code mean?
  • 12,061 Answers
HO... is Water Heating, this means that the water is still heating.
This can sometimes mean that the element, that heats the water isn't working, or the controller, or a Sensor, you will have to troubleshoot to see. use the manuals, and websites, to do this...
http://www.hammerwall.com/Manuals/Frigidaire/Description/FDB2310LCC2/Frigidaire%20Dishwasher%20Service%20Data%20Sheet/154476001/
http://appliancejunk.com/forums/index.php?topic=2936.0
Ok above is your service and repair manual, choose almost any of those manuals shown, just choose one as near to your as you can, as they are all generic, and you can use this manual to troubleshoot and repair your dishwasher. Below are some good DIY help sites too for you.
http://www.managemylife.com/mmh/Troubleshooting_Guides/Dishwasher.pdf
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
Posted on May 07, 2010
What does an E5 code mean?
Make and model helps, but here are all the E5 Error Codes we get asked.
On a cellphone?
E5 code Google Search
On a washing machine
e5 error code code washing machines Google Search
Dishwasher
e5 error code code dishwasher Google Search
Stove / Cooker
e5 error code code stoves Google Search
Fridge
samsung fridge e5 error code Google Search
Aug 27, 2017 | Cell Phones
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a model FDB2310LCC2 dishwasher and it won't turn on. The column cycle lights washing cleaning drying and sanitizing are all blinking simultaneously along with the "high temp wash" light. I...
This may be a problem with the door interlock switches. You will need to shut off power to the dishwasher, unscrew the control panel and remove the wires to the door switch ( make note of where the wires go on the switches) and check the switches with an ohm meter ( do this with the door closed, the switches should show good continuity). repost if any questions.
Jul 11, 2010 | Dishwashers
Dishwasher is on and running a load. It is flashing HO??
The "HO" means it's trying to heat the water to the appropriate temperature before proceeding in the cycle. It's totallly normal, and can go on for 20 minutes or so... if you run your sink faucet to clear the line of hot water first, it will reduce the time it takes to heat the water
Apr 03, 2010 | Frigidaire Professional Series 24 in....
Dishwasher wont drain
Look for food in sump and drain hose, if clear may need drain pump
Mar 03, 2010 | Dishwashers
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
What does Frigidaire dishwasher timer code "Hd"stand for? It's not listed in the manual and I couldn't find it listed online. If it's just a "Hold" code (which is what I suspect) for extra washing time,...
“HO” or “Hd” means the dishwasher’s cycle time is being extended while it is heating water. At certain points in the wash cycle, the dishwasher uses hotter water to ensure a clean load of dishes. If it detects that the water is not hot enough, it will heat it.
If you’re seeing “HO” or “Hd” frequently, check the temperature of the water available to your dishwasher. It’s best to do this at the sink closest to it, allowing the hot water to run until it reaches its maximum temperature before you test it with a thermometer. For best results, water should be not less than 120°F.
Sep 20, 2009 | Frigidaire PLD2855RFC Dishwasher
Error "HO"
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature.
Thank You Huum
Please remember to leave a solved rating before you sign off!
Dec 20, 2008 | Dishwashers
Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Mar 24, 2008 | Dishwashers
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
