Question about Canon PowerShot S1 IS Digital Camera
Black screen in camera mode
I have a Powershot S1 IS, when I turn on the camera on the only thing that i see i a black screen and every once and awhile white lines flash across the screen. If I take a picture all it takes is a black picture with white lines going though it. As far as i know it hasn't been dropped or has got wet. I can see the pictures that i have on the card with no problem.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Posted on May 07, 2010
When turn on all i see is the black screen. what is the couse of that?
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 25, 2009 | Canon PowerShot S1 IS Digital Camera
Our camera when you turn it on has a blank screen and you cannot take pictures. You can review pictures and see the different menu modes, but the screen is otherwise black.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jul 03, 2009 | Canon PowerShot S1 IS Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Same problem. screen is black when turned on. where can i repair?
Jun 21, 2009 | Canon PowerShot S1 IS Digital Camera
Black screen on Canon S1 IS camera
If Canon S1 IS does not show picture in camera mode and show memory card stored pictures in playback then its CCD Imgaer problem and ccd imager will be replaced.
Canon will repair it free of cost, click Canon CCD Imager Advisory for details.
Jun 11, 2009 | Canon PowerShot S1 IS Digital Camera
Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Sep 14, 2007 | Canon PowerShot S1 IS Digital Camera
Canot see subject trying to photograph
Hello, You should contact Canon about the situation. Let them know you are aware of the problem CCD sensor on the S1 camera. Actually S1 is repaired free of charge because of the CCD problem. You should suggest that your camera probably has the same defect as the S1. See what they say. If you need more info please advice. Arpi
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Black screen with white horizental lines there are no error messages
Contact Canon, there is a service bulletin on this issue and they will repair free even out of warranty. They will not fix other problems if the unit is out of warranty.
Apr 28, 2007 | Canon PowerShot S1 IS Digital Camera
Black Screen and Scroll Problem
You're either having a spreading corrosion problem from the water, or it's not all dry in there and it's spreading, and the conductivity of the water is screwing up the circuits. Open the camera as much as you're willing to risk it, and you're going to have to take a chance either way - either you take it apart, expose the boards, and every separate part with some distilled(non conductive) water (if you just dip the whole thing you'll have water caught in places) then put in an airing cupboard to dry for a week, thus taking the chance of causing more damage by not being able to reassemble it properly, or by causing more water damage, or you have another option of just opening all compartments -cards, battery - taking everything out and leaving it to dry, hoping that it will be enough. The chance you're taking here is that it's really a corrosion problem and you'll be helping it set it. If you don't like both option take it to a repair shop. Good luck
Jun 03, 2006 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
457 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
