Question about Corvette Chevy Malibu 90-04 Car Radio Wire Harness
What kind of adapter to install cd player into 2000 malibu
What kind of adapter do you need to install a cd player deck into a 2000 chevy malibu?
  • 3,640 Answers
What you will need is the radio adapter kit for your car make. also you need a wiring connector for the car between car wiring and radio. match the wires to wires on radio, and then the connector will fit car wiring connector, just plug it in to car wiring.
Posted on May 11, 2010
How to wire cd player up in 2000 chevrolet malibu
I just discovered there are wiring harness adapters as I used one on my car to install a new cd player recently. I found this one on the internet not sure if it is the same car you have.
http://www.installer.com/item/display_item.php?it=71-1858
then you can buy a harness adapter from this adapter to the make of cd player like as an example Kenwood Cd player adapter.
A car auto store may know about these wiring harness adapters the advantage of using them is it makes it easy to install the cd player and if you ever decide to change the cd player in the future you can buy the adapter suited to the future player and plug it into the malibu car wiring adapter as the car adapter converts the factory wiring into a universal wiring standard.
A tip
make sure the radio and cd player works and the climate control work properly before completely re assembling the dash board .
I forgot the aerial cable plug !
I used Aeropro brand of wiring harness for my car that I got from
Car Accessory store in my country . I had to cut one wire and connect it to Pontrol to get my power aerial to work correctly. Which the store salesman helped me work out which wire controlled the cars power aerial
Sep 17, 2015 | Chevrolet Cars & Trucks
How to wire up to a 2002 chevy malibu
My 2002 Chevrolet Malibu doesn have wiring harness
You'll be glad to know we do offer an OEM wiring interface from Metra for the 2002 Chevrolet Malibu. If the Chevy Malibu came equipped with Onstar, then here is the adapter you will need to replace the factory radio. If the Malibu did not come equipped with Onstar, then you will need this adapter instead. I hope that helps. Andy
Crutchfield Advisor
1-800-388-2911-ext 3161
The above link has the info on stereo adapters. They are expensive, but these adapters retain the original functions of the system.
May 18, 2014 | Pioneer DEH-3700MP CD Player
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
Whats the proper way to install the cd player into a 1992 chevy pick up truck and if u cud send a manuel
The proper way to install any aftermarket deck into a newer vehicle is to get a factory wiring harness adapter. This adapter will attach to the existing wiring harness for your factory stereo system. You can purchase these from various websites like this http://us.ebid.net/for-sale/1992-chevy-pickup-fullsize-radio-wire-harness-92-17373248.htm?from=googlebase
When you plug this in your factory speakers and power/ground will all be available to wire to your new deck without cutting or splicing any wires. The colors follow the E.I.A standard and should match your new stereo. I hope this is helpful and thanks for using FixYa.
Sep 17, 2010 | Car Audio & Video
2005 Chevy Malibu Maxx cd changer error
You will need to have the radio reset or checked out at the dealer.Ther could be a cd stuck in it.Or the radio/CD player may have be on when the battery power got to low.
Jan 10, 2010 | 2005 Chevrolet Malibu Maxx
Where is the cd player the radio says that there is no disk
Most cd players are in the main dash panel. If you do not have a cd slot, you likely don't have a cd player. These vans usually don't come with them and you have to install an aftermarket cd player.
If you have a cd disc changer, it is likely in the very rear of the vehicle.
Nov 17, 2009 | 2000 Ford Windstar
Cannot play ipod on 2000 malibu using tape adapter. malibu has cd player and remote tape deck
Instead use a radio adaptor where you would set you radio to a particular channel. The adaptor emits a signal correspondent to that radio signal and allows you to listen to your iPod.
Jul 08, 2009 | 2000 Chevrolet Malibu
Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
Jun 10, 2009 | 2004 Chevrolet Malibu
Installing pioneer deck
Considering you have done many installs, make sure you check the fuse in the back of the unit. Then check all the fuses in your car. My car has 4 fuses for the radio.
Jun 30, 2008 | Pioneer DEH-P2000 CD Player
Corvette Chevy  Malibu 90-04 Car Radio Wire Harness Logo
409 people viewed this question
Top Corvette Car Audio & Video Experts
Frank Mangiapane
Level 1 Expert
xxxxxx xxx
Libran Moreno
Are you a Corvette Car Audio and Video Expert? Answer questions, earn points and help others
