Question about Sony Playstation 3 (PS3) Console
Ps3 and other computers in a network
Ever since the ps3 was hooked up, it will either disconnect the other computers from the wireless net, or grab all the broadband so that the other computers lag and slow down to almost a standstill. The disturbing thing is that its not necessary for someone to be playing on the ps3 for this to happen. We are using a gaming wireless router too. HELP. It sucks to be in the middle of a music download or something, then get disconnected by the ps3.
  • deathking201 May 11, 2010
    What type of gaming wireless router u got?
  • ahughs
    ahughs May 11, 2010
    do you have folding @ home installed? If so - turn it off
    Also, verify that your computers are not trying to stream data \ synchronizing with the ps3 and windows media player.
    (start > run > wmplayer [press enter])
    click the down arrow by My Library, go to media sharing
    disable sharing to your PS3
    *shrugs*
  • 39 Answers
Ps3 uses alot of abndwidth if u want u can try using lan cord
Posted on Apr 19, 2010
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
How do I connect my ps3 to the internet and tv so as to view the net on tv?
It's a semi-long process. Do you have a wireless router hooked up to your computer? If so just go to settings then network settings in your ps3 menu. If you have the wireless router then put wireless connection and its straight forward from there. If it is a wired connection and hooked to your ps3 than put wired connection and again its straight forward from there.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
Do I need a 2nd modem to hook my ps3 up to the internet? My ps3 is no where near my computer...how can I get it hooked up to the internet?
I would use a wireless router. Then you can use ps3 or laptop in the house. Or run ethernet from main router/modem to the ps3. You can buy the ethernet cables at amazon.com and newegg.com and they can go a few hundred feet.
Nov 16, 2009 | Sony Playstation 3 (PS3) Console
How do i hook up my ps3 to play on line
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
http://atomsfamily.net/playstation_3_sol…
Sep 11, 2009 | Sony Playstation 3 (PS3) Console
Cant find out how to get my ps3 with internet
if you have wireless you can hook it up that way.
if you have wired or DSL network you can hook it up that way too.
in addition you need a playstation network user account.
to hook up your ps3 to the net go to settings, network connection and choose custom network connection then it will show you wireless or wired then choose whatever you have. then just go through and dont change any settings until it runs the connection test then it should work
REMEMBER TO GET PLAYSTATION NETWORK ACCOUNT IN THE PLAYSTATION STORE AFTER YOU SET IT UP!!!!!
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
D-link to work with PS3
you need to setup your network settings under the settings in the XMB (cross media bar) on your PS3
May 17, 2009 | Sony Playstation 3 (PS3) Console
Help
You can't. For wireless connection on the PS3 you need to have a wireless router hooked up to your modem. Once you have your wireless network hooked up with your PC. You can give your PS3 access and the PS3 will scan for any available wireless networks. Google will help you more if you need more detail on how to set up your PS3 wirelessly.
Sep 10, 2008 | Sony Playstation 3 (PS3) Console
Hi...unable to connect to ps3 using siemans gigaset se587 wireless router
hi there,
first you need to make sure u can access your wireless router with no problems and the wireless is turned on for your ps-3...then u need to forward some ports...
Turn on PS3 and goto Settings, Network Settings.
Select Internet Connections. If it asks you want to be disconnected select Yes. Select EASY. Select wireless
Select SCAN this will take a few minutes. The PS3 should find your router and already have the SSID# so just type in your WEP key. Select save and then wait a couple of minutes then select test. It should hook up.
If it hooks up with NAT3 then you will have to enable UPnP on you router. type in http://192.168.1.1 on your computers web browser.
username: admin
password: admin
Click on the advanced tab and then on Universal plug n play and then make sure both check boxes are marked.
Then on the PS3 make sure the UPnP is enabled also in the network settings.
This should give you network and NAT2.
please try this link for port forwarding help:-
http://www.portforward.com/english/routers/port_forwarding/Siemens/GigasetSE587/PS3_NAT_Type_3_to_2.htm
Apr 20, 2008 | Computers & Internet
No internet ?
When you connect your ps3 with a ethernet cord you need to restart your ps3 when its connected. If its wireless you may need to check your router settings.
Mar 05, 2008 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
