I just bought a Jensen JPA1150M amplifier. I chose this one because of the specified frequency range (10Hz -100KHz).
I want to amplify an Amplitude Modulated signal in the 70KHz range. (Of course I'll have to demodulate this signal before I can hear it.)
#1 Should I be able to amplifiy it OK???
At this point I am just trying to get the amp to work on the bench using a FULLY charged Auto battery. I have the following connections and settings. 1 large 2 ohm Speaker (right channel), + Power,
Ground, REM (on back) connected to + Power, X-OVER at FULL, RCA connector into Right Low Input, 2 Volts Peak to Peak, 2 KHz, going into Right Low Input.
#2 What is happening is that the POWER and STAND-BY lights alternate. POWER on, I have output, STANDY-BY nothing. By truning the LEVEL down low I can keep it on. Does that sound right???
#3 Would I be better off with my input going into the high level input??? Any Suggestions or help is appreciated. Don
Comment by DYoung9, posted on Mar 29, 2008
The other thing I have not been able to do is get output for a single speaker with negative LEFT jumpered to positive RIGHT and the speaker hooked up to the remaining two speaker terminals (+ LEFT, -RIGHT).
Thanks for the answer...
The AMP is supposed to be NEW.
What do you suggest now?
Comment by DYoung9, posted on Mar 30, 2008
I've tested it for my application and it seems to be working for my purposes. I have a very directional receiver that I built and am using this as a balanced signal (one of the 3 methods I'm trying to detect voids with) system. Thanks very much for your input. Don't know if it will find the void yet but I'll know by the end of the week if one of the three works. Don
Rating: 0%, 0 votes
Generally, it's not necessary to connect a jumper between the channels of an amp. If the bridging wires are L+ and R-, it shouldn't be causing any problem.
Have you looked at the signal on an oscilloscope to determine if you're driving the amp into hard clipping? If you are, that may be causing the amp to go into protection.
The high level input is for speaker level signal (as those you'd have if you were driving the amp from an OEM head unit).
Post a New problem for Jensen JPA1150M Car Audio Amplifier
Email this problem
